Side Tank Size? OR WTB "ED" code 4-row Radiator
Old Aug 9, 2025 | 08:58 AM
BackInTheGame's Avatar
I need some dimensions. Does anyone have an OEM 4-ROW "ED" code radiator in a 1968 4-4-2 with AC and Manual Trans? I need to replace mine. The Parts Place Inc has several versions for a 1968 MT 4-4-2, but with varying side-tank dimensions. I'm hoping someone has an OEM "ED" radiator, PN 3017106, who can measure both side tanks and let me know the dimensions Front-to-Back and Left-to-Right for each side. I know the TPP version won't be OEM, but I'm hoping to get as close to OEM specs as possible with the replacement.
OR
Does anyone have an OEM "ED" 4-ROW radiator they are willing to part with?
Old Aug 11, 2025 | 11:34 AM
RocketDevo's Avatar
The ED rad tag code is a 4 core radiator. The dimensions are the same for all A body's 1968-72 as far as length and height.
The width is 2.70 inches as opposed to the 3 core which is 2.00 inches.
The parts place 4 core is correct dimensionally. It does not have the codes on the tank though.
I have a PB code 4 core available if you want an original. The radiator is for a 1970 Chevelle though.
Old Aug 15, 2025 | 04:38 PM
Thanks for your response, RocketDevo! A couple days ago I went ahead and ordered The Parts Place version that is dimensionally correct. It is supposed to be delivered tomorrow. As you note, it will not have the factory correct stampings on the side tank. I'll post up some pics once I have it in hand.
Horsepower
Feb 2, 2024 08:01 PM
stevengerard
Jan 29, 2018 02:11 PM
truckman5000
Dec 26, 2016 04:56 PM
Warren Seale
Feb 19, 2014 08:23 AM
69442C
Jan 19, 2011 04:57 AM
