Shifter base difference
The shifter on the left is the 1971 first type with the short pin for the cable attachment. The shifter on the right is the 1971-72 second type with the long pin for the shifter cable. The base plates were changed to match. The long pin version superseded the short pin version for replacement use in the parts book.
Last edited by shockrebuild; December 1st, 2018 at 02:02 PM. Reason: Forgot picture
