Sealer/putty
Sealer/putty
Anybody recommend a material to replace this stuff? Located between kick panels and interior body duct for cowl. When I removed kick panels they were sealed behind with a **** load of this stuff much like dum dum putty but light grey in color and there had to be 1-2 lbs of it smeared in there. I'm guessing to hold drafts/moisture out?
Paul, I think I used Mortite for stuff like that on my cars. It's a non-hardening type of caulk that comes like 3M strip caulk. You used to be able to get it at Home Depot or hardware stores. Then you need it together. I don't even know if they still make it, spelling could be wrong.
3M seam sealer will work but I have used dum dum just because I had it. I did the heater core on my S-10 about a year ago and that's all I used. I just took a piece and rolled it out into a thin rope.
Here's an example ...
https://www.ebay.com/itm/19189350069...f240%7Ciid%3A1
