repro door hinges
Old Sep 21, 2011 | 05:20 PM
oils66's Avatar
repro door hinges
has anyone tried repro door hinges from fusick or opgi? would like to know if they are good quality, or better off re-bushing old hinges. have rebushed hinges before and they still seem a little on the sloppy side with after market pins and bushings.
Old Sep 21, 2011 | 06:47 PM
Lady72nRob71's Avatar
As long as yours are not bent or missing, or severely damaged, i would rebuild your old ones. I did so with great success, just takes time. Not too hard except for stripping paint. If not doing that, it is easy!
The pin and bushings and hold-open rollers for the 72 Cutlass fit and work great. I think Fusick has those. Rebuilding yours will save you about 100 bucks per door and keep your car more original. Also, you eliminate issues with typical chinesium repros, like holes in the wrong places, etc...
Here is a before and after shot of mine...
https://classicoldsmobile.com/forums...tml#post165496
Here is disassembly, stripping, and painting instructions...
https://classicoldsmobile.com/forums...tml#post155187
Here is the better way to strip them...
https://classicoldsmobile.com/forums...tml#post163073
And here is reassembly...
https://classicoldsmobile.com/forums...tml#post158188
Old Sep 22, 2011 | 04:42 AM
RetroRanger's Avatar
72 Olds CS
+ 1 on Robs repsonse, I rebuilt my old hinges and they are very tight. I would guess if your old hinges are so worn that the pin has worn away some of the hinge hole the bushing fit would be less than precise.
Old Sep 22, 2011 | 05:33 AM
69442C's Avatar
I have experience with the repro door hinges for the 68-72 Cutlass cars and my suggestion to you is to rebuild your originals. The repros fit OK and I didn't have any issues aligning the doors but the detents were not quite right and didn't hold the door open like the originals. The original hinges will hold the door halfway open and fully open. The repros didn't want to do the 1/2 open thing very well. So I rebuilt the originals and installed them. If you want a good deal on a full set of repros let me know.
Brian
Old Sep 22, 2011 | 01:04 PM
oils66's Avatar
thanks, i have another set of o.e.m. hinges that i will rebush and try.
Jerry Howry
Jun 15, 2013 08:41 PM
HonestDave
Oct 29, 2012 03:49 PM
costpenn
Jun 16, 2012 01:05 PM
mauls
Jun 28, 2011 07:47 PM
Lady72nRob71
Oct 5, 2009 06:51 AM
