Relief for Rattling Colonnade T-tops!
Old Sep 13, 2016 | 08:10 PM
76CutlassSalon's Avatar
If you have a '73 - '77 Cutlass and your factory Hurst Hatch T-tops rattle even after you adjust the bumper screw in the end of the clamp, you don't have to "just live with it". Here's one fix I've come up with:
-- Remove the T-tops
-- Find some heat shrink tubing that can just be forced over the tabs at the inboard sides of the top cutouts (yes, it exists).
-- After you have forced it completely onto the tab, cut it off leaving 1/4" or less of excess.
-- Heat it up with a heat gun, being careful to avoid scorching the T-top weather seal.
-- Repeat steps 3 & 4 above, thereby creating two layers of heat shrink tubing on each tab.
-- Trim off excess with a sharp razor blade.
-- Do this three more times and you're good to go!
Jeff
Old Sep 14, 2016 | 02:32 PM
BlackGold's Avatar
Cool suggestion. I like McGuyvering stuff like this. Just one word of warning: The heat-shrink tubing is not likely very tolerant of UV light, so if you drive (or park) the car in the sun a lot with the T-tops removed, you can plan on re-doing this every few years.
Old Sep 14, 2016 | 04:21 PM
76olds's Avatar
Hookers under Hood
I don't have T-tops on my 76 but I'm sure this will help the guys that do on the site. Thanks for posting a fix Jeff !
Cheers
Eric
Old Sep 14, 2016 | 06:58 PM
Thanks, Brian and Eric.
Jeff
crank shaft
Jun 3, 2014 06:53 PM
oldspackrat
Oct 2, 2013 03:50 PM
MDchanic
Mar 25, 2013 05:01 AM
jnssctt
Jun 21, 2012 11:47 AM
thebarrowgang
Feb 28, 2009 04:52 AM
