relay rod or center link
Old Sep 17, 2013 | 12:50 PM
flatlander442's Avatar
Is relay rod or center link the same on manual and power steering on a 66 442? I'm converting my manual to power! I was told a 67 power steering pump is not correct for my 66. How about a 65? they look the same.Flatlander 442
Old Sep 18, 2013 | 10:19 PM
BILL DEMMER's Avatar
Just the facts...
yes, the relay rod/center link/drag link is the same for power, and non-power steering cars(2 possible sizes, 13/16" or 7/8"). as far as the p.s. pump, did you ask whomever said the pump was not the same, why it was different? i'm thinking that the only possible difference would be the pump output pressure. that can be altered, if need be, by replacing the flow control valve with one from a '67 pump.
bill
Old Sep 24, 2013 | 09:48 AM
Octania's Avatar
I believe the '66 and '67 ps pump is the same unit, exc. perhaps Toronado.
I know there are the two "different" center links- could they make it any harder to tell apart- really, 1/16" diameter difference? WTH?
I was under the impression, perhaps from experiences, that mainly manual steering used the one type and power steering used the other.
And, you know, God forbid they use the same taper, so you can only interchange as a complete setup from (and including, I think) Pitman Arm to idler arm. If the tie rods work on either then I am sure someone got fired for that oversight.
Old Sep 25, 2013 | 09:28 AM
Just the facts...
as far as the pumps go, you should be able to use any pump from an a-body, of that pump style, other body styles would still have the same pump, but there will likely be a different flow control valve(higher pressures for larger bodies). there might be an issue with pulleys, too. those pulleys can be a drag to get off the pump shaft-you need to remove them carefully as the pulleys like to distort if you use an incorrect method.
bill
BILL DEMMER
34
Jun 8, 2021 11:45 PM
RandyS
Nov 30, 2019 02:46 AM
pcard
May 14, 2014 01:21 PM
BILL DEMMER
Nov 21, 2013 09:38 PM
oldzy
Mar 22, 2011 04:33 AM
