Question about valve covers
Old Feb 18, 2023 | 12:36 PM
sx455raidercelticfan's Avatar
Hi guys got another question, where can I find adorable tall aluminum valve covers for my 455??
i found a set on eBay but there’s no holes, I’m pretty sure I need them with holes, here’s a pic of the ones on eBay
Old Feb 18, 2023 | 12:40 PM
66SportCoupe's Avatar
You have to machine breather holes in those.
Old Feb 18, 2023 | 12:47 PM
Like this
Old Feb 18, 2023 | 12:56 PM
Funkwagon455's Avatar
Adorable??😅. Be mindful of your clearances. (A/C, brake booster, accessory brackets). Those are also available in script.
Old Feb 18, 2023 | 01:02 PM
Bfg's Avatar
Bfg
Those are adorable!
Old Feb 18, 2023 | 05:54 PM
VI Cutty's Avatar
Like this
Looks like you have a baffle fitted? What does the backside look like? I'm still working my way through that part of my setup.
For the OP, I've seen a few different ways of tackling your question, including pulling from the intake manifold and oil fill tube instead of boring into the covers. I will likely have the machine shop open up holes like 66sportcoupe is showing.
From what I've read this version of tall cover won't clear the 11" brake booster, and even a 9" (maybe 8") required some clearancing of the valve cover...which I'm not willing to do. I'm going with a hydraboost system so it won't be an issue for me.
Old Feb 18, 2023 | 05:57 PM
I opened mine up on a manual Bridgeport mill. No baffles installed. No issues. Any brake booster you buy won't work. Manual brakes only.
Old Feb 18, 2023 | 06:03 PM
Old Feb 18, 2023 | 06:42 PM
THANKS GUYS!!!! That’s the information I needed!!! I have a 8 inch booster but if those valve covers won’t work with a 8 inch looks like I’m going to use original with spacers!!
as always thanks for all the help!!!!
Inline
Jun 13, 2021 05:33 AM
815Cutlass1972
Dec 16, 2020 02:19 PM
FTW65W29
May 7, 2015 08:27 PM
Stevec
Jan 23, 2014 03:09 PM
valvecoverred
Mar 26, 2012 07:17 PM
