Proportioning valve cable
Old Nov 29, 2021 | 12:07 PM
matefis's Avatar
Hey all,
Could someone please confirm that this cable is truly the lead to the original proportioning valve? If it's not, any suggestion what it might connect to? Thanks a lot. Mat
Old Nov 29, 2021 | 01:32 PM
Thats it, to verify just turn on the key and ground the wire end, the brake light should come on with the Ebrake off.
Old Nov 29, 2021 | 01:33 PM
That wire connects to the brake differential pressure switch that is built into the combination valve or distribution block (what people incorrectly call a "proportioning valve"). The purpose of the differential pressure switch is to illuminate the BRAKE light on the dash if you lose pressure in one half of the dual circuit brake system.
Schne442
Jun 16, 2020 05:06 PM
Jacoz70442
Apr 18, 2019 08:13 AM
kuseetha
Sep 8, 2018 11:04 PM
76cutlass
Apr 5, 2017 05:50 AM
1971viking
Oct 26, 2011 05:17 PM
