Power Trunk Release Wire Clips - Location?
‘70 - ‘72 A-Body. Power trunk release wire. Does the power wire route inside or on the outside edge of the passenger side trunk hinge? Where do the two clips attach that hold the power wire? On the trunk lid hinge?
I’ve seen a diagram before, but can’t locate it in any of the manuals. An image would help.
Thanks in advance.
Thanks in advance.
Where is the factory correct location for the power trunk release wire and wire clips on a convertible. Image shows passenger side trunk hinge area. Wire is routed through passage hole in trunk to trunk release latch. Does the wire clip to the outside edge of the trunk hinge or to the inside edge of the trunk hinge?
