Overheating issue 1970 cutlass s 350 & others
#41
Thanks guys, guess I can leave the fan positioned as is. The radiator and fan clutch are both new so that's not the issue. I'm thinking it could be the timing. I'm going to check the point gap, then get a timing light to see how it is set.
#42
Location: from Wisc, then Texas, then Kansas, now back to Texas,
check the fan blade pitch, should 2''....I fought with mine for 2 years before I realized the wrong fan was on it. Under 2'' it will not pull enough air, especially with a modified engine
#43
Hey Guys,
I wanted to circle back to let everyone know I was able to resolve my overheating problem. Turns out the rebuilt water pump had gone bad. We trailered the cutlass back to the machine shop for help troubleshooting. He reset the timing per his build specs, I installed a new (not rebuilt) water pump and we were good to go. Haven't seen the car or my teenage boys since
Againm thanks to Everyone for helping me diagnosis the possible cause of the problem. It's great to have a community of knowledgeable folks to turn to, and learning so much along the way!
Now, we just have to figure out why the heater doesn't.. getting darn cold here in St. Louis...
#44
How can a water pump go bad?
Hey Guys,
RetroRanger
February 25th, 2014 05:04 PM
Aussie67Delta88Custom
February 14th, 2008 04:49 AM
