Original Pwr Steering Pump Pulley?
Attached are photos of the power steering pump pulley removed from my '69 Hurst/Olds.
Stamped on the front of it are "FRONT KH" and "S".
Its diameter measures 6 9/16".
I'm needing help in verifying if it is likely the original pulley (or at least if it is correct for the '69 H/O application).
Thanks.
Thanks.
It looks remarkable like the pulley on my car except a 2 groove. Here's a listing from the Olds Parts Manual. Hope it helps - it doesn't list the letters on the pulley, neither does the exploded views. The measurement might be of value to you though.
Thanks for your prompt, detailed and helpful response.
KH Power Steering pulley
Tom:
According to the '69 assembly manual, the KH pulley was used on AC cars with 350 cid or 400 cid engines in 1969. The assembly manual doesn't speak specifically to HO cars only the engine size - see attached page below.
Rodney
Rodney
Thanks a lot for your help.
Now I'm hoping I can find a replacement for mine, as the center "hub" is in bad shape.
