Oldsmobile Broadcast Copy Examples
I found this on top of a gas tank back in the early 90s, and just today found it in a drawer. When I found way back when no one had seem them, and all my Olds buddies said it can’t be from an Olds, it’s from a Chevie, the gas tank was changed, bla bla.
Twenty eight years worth of reference material later (definitely not that I’m any smarter) I see a 1967:
SEQUENCE: 007 or 087
SERIAL NO: 126548
IDENT. NUMBER: 324206
TRIM: F = Could not find
BODY COLOR: YY = Safron upper and lower
MODEL: 33617 = F-85 Deluxe Holiday Coupe
TRANS:
TYPE: 4 = Four speed
SH: F = Floor shift
SEAT: A = black interior?
ENGINE:
CYL. 8
OPT. QU
No power steering
Power brakes = unreadable
With Posi Axle
With Radio
ENGINE: QU = 330 low compression
Carburetor:
FRT. NH = four barrel
GENERATOR BELT: LB = Listed in ’66 and ’67 PIMs
BRAKE CYL: PK = Could not find
AIR CLEANER: SP = Could not find
EXHAUST SYSTEM: LD = Could not find
TRANS: HP = Wide ratio M-21
SPEEDO: 26
FAN: JG
PULLEYS
W/PUMP: JG = #39113 1967 PIM Page 6-1 1.10
GEN: AG = #110767 37 Amp
PROP SHAFT: Something W, could not find
Frame: GJ = Standard car frame
Front Springs & shocks: Standard car
Rear springs and shocks: Standard car
WHEELS: BA = Could not find B reference, but A is standard car wheel EXC. EXT. S.W.
TIRES:
775 14”
Sure seems like a car I wouldn’t be ashamed to own.
Does anyone have another broadcast example?
Gregory Glancy
September 29th, 2020 08:31 PM
greyghost
November 1st, 2009 09:39 PM
