Odds and Ends
Old Apr 11, 2013 | 03:44 PM
'73Al's Avatar
Odds and Ends
where does the black short wire on distributer go? Where does the Tranny modulator vacuum line plug into? I'm tryn to reassemble some one elses project..i got car partially disassembled
Old Apr 11, 2013 | 04:37 PM
I'm assuming the black short wire is the ground strap from the distributor body to the advance plate. Transmission modulator gets full manifold vacuum.
Old Apr 11, 2013 | 05:29 PM
Unless it's the points wire, in which case it goes to the (-) terminal of the coil.
And, as OldCutlass said, the modulator goes to whichever barb on the intake you want it to. If you're very obsessive, you could look in the Assembly Manual and see where the factory put it.
Old Apr 13, 2013 | 04:11 PM
'73Al's Avatar
Thanks for the help fellows!
Old Apr 13, 2013 | 04:16 PM
'73Al's Avatar
what about the condenser wire on the coil..I'm figuring the poitive terminal on coil. Where does that one go. Sorry to seem so unknowledgeable...
Old Apr 13, 2013 | 04:21 PM
Do you mean the radio interference condenser screwed to the coil bracket?
Its wire goes to the (+) terminal of the coil.
Old Apr 13, 2013 | 06:30 PM
'73Al's Avatar
yes..I called a buddy and he said it goes to the positive side of coil
2blu442
Jan 17, 2021 08:01 AM
Hairy Olds
Jun 17, 2013 08:55 PM
Olds Dad
Feb 11, 2011 09:07 PM
crazy'boutOlds
Jul 19, 2009 02:52 PM
crazy'boutOlds
Oct 8, 2008 07:26 AM
