Intake Air Quality
Old Jun 6, 2009 | 01:38 PM
jimjr's Avatar
Intake Air Quality
Hi, My '67 Olds Cutlass (330c.i. w/4bbl. Edelbrock 1406) has valve cover breather filters which emit visible fumes during engine operation. The air filter is sandwiched between two chrome dishes with the perimeter of the filter exposed for air intake. I'm sure the fumes are being sucked into the carb., making the mixture dirty and very hot. Any ideas out there as to maybe using some sort of remote air intake like the K&N kits? Should I try a hood scoop? Any ideas are greatly appreciate! Thanks, Jim
Old Jun 6, 2009 | 06:31 PM
So you're not running a PCV valve? If you are, it's apparently not working, and if you're not, that's why you are getting blowby oil smoke out of the breathers. Fix that, not the air filter.
70F85
Sep 22, 2013 08:22 AM
svnt442
Jul 17, 2011 04:43 PM
jimjr
Jan 28, 2011 07:23 AM
cormike
Aurora
Jan 4, 2009 07:30 AM
