Installing a shifter and console
Old Nov 2, 2010 | 09:27 AM
fiona72's Avatar
Hello all,
I purchased a used automatic floor shifter and console for my 72 cutlass. Are there any tips for getting the console over the shifter after the shifter is mounted? I removed the shifter ball of course, but can’t place the console over it. It looks like there are drift pins holding the “T” handle in place, do I punch these out? Also, the car goes into park, but will not let me remove the key without moving it myself (on the steering column) should I adjust the cable itself?
Old Nov 2, 2010 | 10:05 AM
svnt442's Avatar
It's not the cable, but the linkage from the trans to the column that is loose. Mine is the same way. I just deal with it but it should probably be refurbished with new bushings and that would take care of the problem.
Old Nov 2, 2010 | 10:10 AM
vette442's Avatar
Yes, you need to slide the pins out of the T portion of the handle to get the console over the shifter, then reinstall the T and pins.
jpc647
Oct 29, 2014 03:18 PM
marxjunk
Jun 12, 2014 12:34 PM
mdavis9886
Mar 3, 2012 07:18 PM
bass man
Sep 24, 2011 01:01 PM
The Stickman
May 12, 2009 06:57 PM
