IDing the flywheel 1964
Old Sep 9, 2019 | 01:00 PM
deaddds's Avatar
Ive got a couple different flywheels that came with some parts. One looks to be what I have on my spare 394 in terms of its about 1/2" thick with the teeth and I assume the damper plate attaches to it. Those were already separated. The other flywheel is tons heavier, looks like it has a ring embedded into it and is a good 1" thick with teeth. Is the one for automatic and the bigger one manual? I dont see any casting numbers in either. Thanks
Old Sep 9, 2019 | 03:10 PM
59-59-59's Avatar
If you want a pic of a ‘62 394 automatic flywheel, let me know if that will help you out
Old Sep 9, 2019 | 03:23 PM
deaddds's Avatar
Sure, can’t hurt. Like I said, the skinny wheel looks to be what is on the 394 engine already. So I’m guessing the other is for ST.
Old Sep 9, 2019 | 03:37 PM
59-59-59's Avatar
‘62 flywheel- zoom in and you’ll see 2 dowel pins there
Old Sep 9, 2019 | 05:06 PM
deaddds's Avatar
That certainly looks like the other one i have, the thick one. So im guessing 61-2 are different than 63-4?
Old Sep 9, 2019 | 08:47 PM
Charlie Jones's Avatar
Phantom Phixer
Yes they are . Here's a '63 manual flywheel ; 166 tooth ring gear .
Old Sep 10, 2019 | 04:43 PM
deaddds's Avatar
Both have 166 teeth. This is the skinny one I think for automatic.
deaddds's Avatar
Old Sep 10, 2019 | 04:45 PM
deaddds's Avatar
This must be the 61-2, but not manual?
Old Sep 10, 2019 | 08:11 PM
Phantom Phixer
Pat ,
The first pic is an automatic flywheel , But It's not for a 394
It maybe looks like a 2nd generation flywheel . I'm not sure which one , '68 and up had a different center hole diameter .
Second and third pics show a 394 automatic ( slim Jim ) flywheel ( note the very large center hole dimeter ) .
I'm not sure what year , '61 was different than '62 , which is also different than '63 & '64.( according to the parts book and the Hollander )
I can post a pic of a '63 automatic flywheel for you tomorrow .
Old Sep 10, 2019 | 08:17 PM
deaddds's Avatar
Ok, it sure would be easier if they cast a part number in the damn parts.
rodney391
Oct 4, 2019 08:10 AM
rodney391
Sep 25, 2019 02:43 AM
Maddynamic
Oct 3, 2018 07:02 PM
NAS Backyard
Mar 26, 2012 08:20 PM
marxpups
Sep 19, 2011 06:15 PM
