Identifying a 1970 OAI Hood
Old Jun 26, 2017 | 06:16 AM
jharsh's Avatar
I thought there was a post somewhere on how to identify an original 1970 OAI Hood, but I can not seem to find it. I just bought a second Rallye 350 and the inside of the air inlets look slightly different then my first Rallye. Are there distinguishing marks to tell if a Hood is real or after market. Was there any other GM car that used a hood similar to the Oldsmobile Hood. I ask because on the car I just bought the screen on the inside of the Hood seems to have a triangular pattern ( with rounded corners) in the center. Almost like the air cleaner assembly had that shape at one time. I can post a pic tonight if it would help.
Thanks,
Old Jun 27, 2017 | 03:50 PM
jharsh's Avatar
I thought I had read somewhere that there should be a hole on the inside edge of the inlets. I do not see them here.
The other thing I found odd was the triangular shape in the screen.
There is a part number marked in chalk near the back that appears to be the correct part number for a 1970.
What are your thoughts.
Old Jun 27, 2017 | 04:31 PM
70-442-W30's Avatar
344879M363895
Yes, I had the holes on mine. But you'd have to get someone else's expertise on the matter because I just don't know enough about them. What was the build date on this car?
Old Jun 27, 2017 | 04:34 PM
70-442-W30's Avatar
344879M363895
There was some good info and lots of pics in this thread: https://classicoldsmobile.com/forums...tml#post948769
Old Jun 27, 2017 | 04:39 PM
jharsh's Avatar
This Rallye has a build date of 02C. I tend to believe it is the real thing, but would really like to know the things to look. My other Rallye has the hole on the edge like yours.
Old Jun 27, 2017 | 04:43 PM
70-442-W30's Avatar
344879M363895
Just curious is your other Rallye earlier than a 02C?
Old Jun 27, 2017 | 04:46 PM
jharsh's Avatar
Yes, by one month. It has a build date of 01C. Here is a pic of the intake on that one.
Old Jun 27, 2017 | 04:53 PM
70-442-W30's Avatar
344879M363895
I've wondered if that had something to do with it. Now I'm wondering if this was ever referenced in the Oldsmobile PIM as a possible update.
I like the Rallye cars. Not everyone loves yellow on a car, but I never had an issue with it and actually prefer it over many colors. Congrats on owning two!
Old Jun 27, 2017 | 05:03 PM
jharsh's Avatar
Thanks, one is a bucket seat with automatic and the other a bench seat standard. I really like them. I am going to stand both hoods next to each other and see what other differences I see.
Old Jun 27, 2017 | 07:00 PM
anthonyP's Avatar
Wow, nice find. Always good to see another Rallye being saved. Way too many dismantled in the past to restore/upgrade the thought of at the time 'better' Oldsmobile models.
Old Jun 28, 2017 | 09:56 AM
Magna86's Avatar
Um where are the pics of this new find? :-)
Old Jun 28, 2017 | 03:14 PM
Apparently there were to be flapper doors in the snoots of the original hoods. The feature got kiboshed, and the holes went away with a mold update.
Old Jun 28, 2017 | 04:04 PM
anthonyP's Avatar
Interesting, never heard about original plan to install ‘flappers’ in the W-25 hood, not unlike the GTO, GTX, and some other cars with ram air so they could be manually opened and closed.
Wonder if there is any documentation showing that was the original intent and how the dual flapper system would had been assembled. Presumably the hood flapper system would had allowed manual operation.
If true, wonder if it is was abandoned to the complexity of a hood flapper set-up or due to the ease of using a air cleaner flapper assembly? Having the option of when to open or close the ram induction would had been nice. It also might had allowed a larger opening in the air cleaner assembly.
Another interesting tidbit that keeps this 'hobby' interesting.
Old Jun 28, 2017 | 05:34 PM
jharsh's Avatar
Did anyone notice the triangular shape in the hood screen in my 2nd post. What type air cleaner would have caused that?
Old Jun 28, 2017 | 06:01 PM
70-442-W30's Avatar
344879M363895
Just searched through my pics and found a good shot:
Old Jun 28, 2017 | 06:13 PM
jharsh's Avatar
Now I am really curious as to why that is there. Hopefully someone has an answer.
Old Jun 28, 2017 | 07:04 PM
RetroRanger's Avatar
72 Olds CS
Old Jun 28, 2017 | 07:39 PM
70Post's Avatar
Most likely to clear the top/rear/center portion of the plastic flapper and/or to add stiffness to the screen itself. It was most definitely stamped into the screen when it was formed and wasn't caused afterwards by anything pushing up against it.
Old Jun 29, 2017 | 08:41 AM
anthonyP's Avatar
Do all of the factory W-25 hoods have the indented screening? Is it just the '70 hoods or also the 71/72 hoods?
Old Jun 29, 2017 | 12:05 PM
Magna86's Avatar
My 71's hood has the rounded triangular shape in it as well and was confirmed as real by Joe down in TX when he looked at it.
Hurst/Olds 73/74
Sep 24, 2016 09:31 PM
camshaw
May 4, 2015 11:53 AM
rtbtms
Dec 2, 2012 12:58 PM
guy.graziano
Mar 21, 2012 09:32 AM
guy.graziano
Dec 5, 2010 12:10 PM
