how to tell 350 from 455 in 1970 olds
Old Mar 11, 2009 | 12:16 PM
mahoneybags21's Avatar
how can i tell if the cars got the 350 or the 455?
Old Mar 11, 2009 | 12:24 PM
and is the 1970 350 a big block or only the 455 was a big block
Old Mar 11, 2009 | 12:45 PM
citcapp's Avatar
Here's a couple of ways (others will chime in with more)
Big Block 425 and 455
425 painted red ,455 painted blue, 350 painted gold
letter designation above the number one cylinder A or B or C or D or E or F or G or Ga etc.
number designation above the number one cylinder 5 or 7 etc
Thats for starters
Old Mar 11, 2009 | 01:55 PM
jensenracing77's Avatar
the 350 is a small block. the fastest way to tell a small from a big is to measure the intake manifold. the big block is 14 inches wide and the small block is 12 inches wide. small blocks are 260 330 350 and 403. the big block is 400 425 and 455.
Thats for starters
Well, paint and cylinder heads can be changed. The only foolproof (and very easy) way to tell is to look at the block casting number. This is located on the small shelf above the water pump, where the oil fill tube goes into the block. Compare that number to these:
http://www.oldsmobilewiki.com/index.php/Category:Blocks
Also be aware that conventional terminology with Olds motors uses small block to refer to the short deck motors and big block to refer to the tall deck motors. Small blocks came in 260, 307, 330, 350, and 403 cu in displacements (including 260 and 350 diesel motors). The big blocks came in 400 (long and short stroke), 425, and 455 cu in displacements.
Old Mar 11, 2009 | 01:58 PM
thanks joe, i forgot the 307. oops
Old Mar 11, 2009 | 06:22 PM
im goin to look at a 1970 delta 88 and the guy says it has the big block engine so the best way is too look at the casting number?
Old Mar 11, 2009 | 06:31 PM
or does the vin number tell if the 455 would be in it?
Old Mar 11, 2009 | 06:47 PM
marcar1993's Avatar
Look next to the oil fill tube, if the # is "396021" then it is a 455.
This is where it will be (this is a torn down 68-76 350, location will be the same, also this is the casting # if it's a 350.)
Old Mar 11, 2009 | 06:52 PM
The engine code was not included in the VIN before the 1972 model year, so no.
Old Mar 11, 2009 | 07:05 PM
kk the pic helped alot thanks
Old Feb 28, 2016 | 01:08 PM
serta1's Avatar
I have the exact same casting number on my engine. 395558-2. Is there any way to narrow it down any more?
Old Feb 28, 2016 | 01:14 PM
Resurrecting a SEVEN year old thread...
Narrow what down, exactly? That casting is a 350 Olds from 1968-1976. The VIN derivative stamp will tell you the model year of the block. The head casting numbers will tell you the year of the heads. More than that requires disassembly to check specific parts.
Old Feb 29, 2016 | 06:33 AM
serta1's Avatar
Casting
Sorry I did not check the date of the postings. I just did a search on the site. The heads have a large number 7 on them by number one plug. I believe that means 70 or 71. Non hardened valves. Thank you for the information.
Old Feb 29, 2016 | 06:37 AM
Not sure where you searched, but No. 7 heads were used in the 1971 model year only and the DO have induction hardened valve seats, as to all Olds heads from the 1971 model year forward.
Old Feb 29, 2016 | 07:19 AM
serta1's Avatar
Casting Number
I looked on one of the Olds sites. It said that 7A were hardened but of course it could have been incorrect. Thank you for the information.
Old Feb 29, 2016 | 07:20 AM
oldsmobiledave's Avatar
or
Drive the car. If your fillings come loose on acceleration that is a 350. if your fillings pull out of their teeth then you have a 455. Simple.
Old Feb 29, 2016 | 07:24 AM
FYI, starting with the 1971 model year, every Olds engine was required by federal law to be compatible with then-new low-lead gasoline (and shortly thereafter, no-lead). That required hardened seats and lowered CR. Keep in mind that the hardened seats on factory Olds heads are simply an induction hardening of the cast iron that only goes a few thousandths of an inch deep. These heads did not use press-in seats.
There's a lot of incorrect info on-line. Those of us who were alive then remember it clearly.
Old Feb 29, 2016 | 07:37 AM
rocketraider's Avatar
Oldsdruid
Oh lord. That puts it as succinctly as I've ever heard it!
pfergy600
Jun 15, 2014 03:20 PM
70vert455
Jun 25, 2012 06:22 PM
rmac1970
Apr 17, 2012 06:31 PM
73olds350r
Jul 25, 2011 07:49 PM
Huron
Jul 10, 2007 08:35 AM
