Hooker headers install question
Old Mar 17, 2014 | 01:59 PM
snylften's Avatar
Hello all. I just recently purchased a set of Hooker Headers for my 1971 Cutlass Holiday Hardtop. It has a 350, I dont know the exact year, but between 1977-1980. I have managed to get the manifolds down and getting ready to install the headers. I have no experience doing this before, so I was wondering if you could get me some info on how to install them.
Will the starter have to come of, do I need to get the steering linkage separated etc to get the headers to fit? It looks kinda tight.
Should they be installed from the top or do I try and slide them in from under the car?
Old Mar 17, 2014 | 02:09 PM
They need to be installed from underneath and it's a lot easier if you raise the front of the car as high as you can and support the frame on jack stands. The dipstick, oil filter, and possibly the starter need to be removed. You also may have to disconnect your transmission linkage. You may have to take the big bolt out of the engine mounts and raise the engine with a jack on each side to slide them in place.
Old Mar 17, 2014 | 02:15 PM
70cutty's Avatar
Beer Connoisseur
When I installed mine I had to raise the engine a little bit from each side.
Old Mar 17, 2014 | 02:30 PM
455man's Avatar
I took off the oil filter housing also. Starter always comes off when I'm putting headers on.
Old Mar 17, 2014 | 02:56 PM
Eric Anderson's Avatar
I just put hookers on my 350, the starter had to come off, along with the dipstick tube on the drivers side. I also popped the shift linkage off just for a little extra room to get in there not needed though. On the passenger side I popped off the oil filter, I also loosened the transmission lines, if I had the car higher I don't think I would have needed to loosen them but up on jack stands I just couldn't get by them. The cross member clearance was no problem I didn't have to lift the engine, looks like you are using the 3901's which I used I had plenty if room.
Old Mar 17, 2014 | 05:40 PM
breadfan's Avatar
Agree with all the other posters with regard to starter, dipstick, oil filter and also the shift linkage. Also, be aware that if your cutlass is an S model, there's a possibility that the headers may contact the cross member on the drivers side (I have yet to find a rational explanation...maybe someone else on here can help with that). I had to make a few modifications to mine in order to get enough clearance. An added suggestion is while you have the starter out you hay want to wrap it in heat resistant tape or maybe manufacture a heat shield for the starter. You'll see what I'm talking about when you get it back in. Good luck!
Old Mar 18, 2014 | 12:15 AM
snylften's Avatar
Perfect! This is just the type of info I was looking to get! I’m really grateful for your help. I will do some more work asap and get beck here with the progress. The headers came with different lengths on the bolts. Do you know where the longer one goes?
Thanks!
Old Mar 18, 2014 | 02:48 AM
boese1978's Avatar
I use an engine hoist to raise the engine a bit 1 side at a time( take out the motor mount bolt on one side, raise a couple inches, install the header, replace the bolt, move on to next side), this helps so you don't have to install from underneath as that sucks big time.
Old Mar 18, 2014 | 04:28 AM
Thanks!
I used the longer ones on the ends with a washer where the flanges have a slot. Also on the drivers side where the power steering bracket bolts up I used the factory bolt with two washers to space the bracket out.
Old Mar 18, 2014 | 07:38 AM
NOOOOOOOO! Please, not another "headers won't fit" myth. There is absolutely NO mechanical difference in frame, crossmember, sheet metal, suspension, or engine location on the Cutlass S or Supreme or any other Olds A-body for a given year. The only reason why headers would contact the crossmember is because the rubber motor mount on that side has deteriorated and sagged.
Old Mar 18, 2014 | 07:45 AM
Oldsguy's Avatar
Past Administrator
Moved thread from Newbie section to here. No need to keep posting in the newbie section.
Old Mar 18, 2014 | 08:29 AM
Skitch72's Avatar
I just installed these same headers on my 72' 350...I will throw in that I replaced the engine mounts at the same time and did lift each side of the motor during the install. Since you have good access the motor mounts are never going to be easier to replace. Also removed the already mentioned items starter/dipstick/oil filter& mount.
Does anybody have a pic of how they routed their transmission cooler lines after the install? In order to get clearance I have them routed essentially under the oil filter which is a pain to get on and off. Is there a better way to route them?
My .02
Tim
Old Mar 18, 2014 | 08:42 AM
70cutty's Avatar
Beer Connoisseur
I installed barb fittings on the tranny and 6" of rubber hose, attached the transmission cooler lines to the hose to route them away from the headers. Otherwise they are too close.
Old Mar 19, 2014 | 12:36 AM
snylften's Avatar
I managed to get the headers in place on the passenger side after unmount of the oilfilterhousing. Then it was no problem to get the headers in place. But it was not that simple to get the bolts in place, ill guess my hands are to big. I will give it another try as soon as possible. Two bolts are now holding the header in the right place.
I unmount the starter yesterday and try to put on the riverside header from underneath but it was still to tight. I will try by unmount the steering thing(don't know the name in english) Then i try again to put the riverside header in place. I really don't want to raise the engine
Many thanks guys, and excuse me for my poor english. I really grateful for your help.
Old Mar 19, 2014 | 03:40 PM
Removing the steering shaft will help, just be careful to reinstall it in the same orientation. The flange at the steering box has two different sized shoulder bolts so that it only goes on one way. The splined end at the base of the steering column also only goes on one way.
Also, I have never been able to install headers without lifting the engine. This is no big deal and will really make your life easier. Remove the one bolt between the motor mount and the frame mount, then jack the motor with a floor jack and block of wood under the oil pan sump. Slide the header in, lower the motor slowly, start the header bolts, and reinstall the motor mount bolt and steering shaft.
Old Mar 20, 2014 | 01:38 PM
snylften's Avatar
I removed the steering shaft and that helped a lot. I did remove the oil dipstick to. Then it was no problem to put the header in place. But i did face another problem. The plate where you attach the generator blocks the headers first mounting hole. I have to cut a piece of it so i can mount the header properly.
Thanks again for all your help
Old Mar 20, 2014 | 01:47 PM
Skitch72's Avatar
I think that bracket should hinge away from the block and then lay flat on the flange of the header, you shouldn't have to cut it. That first bolt will go through the bracket and the flange.
Old Mar 20, 2014 | 03:13 PM
NOOOOOO! Simply loosen the alternator bracket, move it out of the way, install the header, and bolt everything back together. That part of the bracket is important to stabilize the alternator and PS pump under belt tension.
Old Mar 21, 2014 | 12:23 PM
snylften's Avatar
ok i understand that now. I did move the alternator. But then the bracket and the hole in the engingblock did not align. I cant figure out how it all of a sudden not align? When i tock off the old ones it was ok but now it has moved? Look at the picture.
Old Mar 21, 2014 | 12:25 PM
RetroRanger's Avatar
72 Olds CS
is the belt still on ?
I think you just need to loosen all the bolts for the brkct and muscle it into place
Old Mar 21, 2014 | 12:37 PM
^^^This.
Remove the alternator. Loosen ALL the bracket bolts. Install bolts loosely. THEN tighten. Reinstall alternator.
Old Mar 21, 2014 | 12:46 PM
Can you post a photo that shows your alternator bracket? From this photo, it appears that you have the late-1970s bracket, which probably came with the engine.
Old Mar 21, 2014 | 01:14 PM
455man's Avatar
It looks like the header flange might be hitting the bracket. I had to grind a little on mine. Maybe and 1/8 of an inch.
Old Mar 21, 2014 | 01:30 PM
That's what I was thinking also, which is why I asked for better photos.
Old Mar 21, 2014 | 10:48 PM
snylften's Avatar
I havent loosen all the bolts yet, ill do that sometime today i hope.
Grinding a bit off was my guess too. I try loosen all the bolts on the bracket first.
Here is some better pictures of the bracket.
Old Mar 22, 2014 | 06:49 AM
therobski's Avatar
I know that on the early A-body's 64-67 the best to install the headers was as mentioned lift one side of the motor at a time. That said, if you using the stock GM starter hows the clearance between the starter and one of the header tubes? On my 67 455 you cannot barely get a sheet of paper between the too. In extreme Texas summer heat the solenoid gets heat soak when I shut the motor off. In addtion if the starter needs service I have to raise the engine, remove the header out of the way to get the starter out. When that time comes I will re-install a new mini starter.
Old Mar 23, 2014 | 12:56 PM
snylften's Avatar
Well today i got the header in place on the driver side. But it is so tight that i had to use a hammer and force in to place. Now it is impossible to get the gasket between the header and engineblock... It seems like the only solution is to remove the bolt that holds the motor.
Old Mar 23, 2014 | 01:59 PM
Not to say "I told you so", but...
Old Mar 23, 2014 | 10:52 PM
snylften's Avatar
i know But i had to grind a bit of the bracket anyway. Otherwise the header wouldn't be able to slip into place. The thing is when i muscle the header into place the gasket was totally mashed between the block and header. Thats because there is no space between the frame and the header on the driverside. On the passangerside on the other hand there was no problem at all, just to set the header into place and mount it.
I have a question about the motor bolt mounting hole. Do i have to compleatly remove the bolt from the engine/chassi bracket? I was thinking maybe there are some room for adjustment in the holes?
Old Mar 24, 2014 | 06:10 AM
The bolt must be removed to lift the engine. Put a wide piece of wood on a floor jack and lift under the oil pan once the bolt is removed. The wood will distribute the weight and not damage the pan.
Old Mar 16, 2023 | 10:46 PM
  #31
Sarum's Avatar
From what I have learned the "difference" is the fact that the distance between chassis rails on a '64 to '67 Cutlass is narrower than subsequent models. While not a major issue with tall blocks like the 455 it is a major one with original 330 cubic inch [SBO}variants which have a lower exhaust outlet height. For this reason it has been said that you can't put BBO long tube headers in a 330ci Cutlass. I do know of one person in Norway or Denmark who managed to put Hooker 3902 model headers in his 1965 330 Cutlass but I remember noting how low the headers hung down but never saw how they were fitted. Hammer of Thor maybe!
Old May 13, 2024 | 07:41 PM
  #32
Sarum's Avatar
Hi from New Zealand, due to continuing ill health the car has sat for about 2 years now. I know this post is old but it is relevant to what I'm attempting to do as I am trying to test fit SS ebay headers to my '65 Cutlass which are meant for BBO engines. I am working on the passenger side as it is the easiest and checking to find out how low the headers will hang underneath the car as I know the exhaust ports are lower on the SBO 330ci. So far I have removed the oil filter and its mount, transmission dust cover trans cooler lines and engine mount on the passenger side. It is fairly close to going in from underneath now but I am looking at jacking up the engine to get a bit more clearance. When you jacked up the engine on your car did you still have everything still attached eg transmission, radiator hoses, etc? From what you wrote you took out both of the big bolts from both engine mounts? Where did you place your jack(s) on the engine? To me it looks like the only place to place a jack is under the front of the oil pan which is a little scary as I would hate to damage the oil pan. What are your thoughts? Cheers Norm
Old Jun 6, 2024 | 03:27 PM
  #33
Sarum's Avatar
Well I finally managed to get the passenger side header test fitted into place after many hours of frustration. For anybody else trying this I had to remove the oil filter and the filter mount, removed the passenger side engine mount, removed the long bolt on the driver side engine mount,
removed the torque converter cover, disconnected and moved the transmission fluid cooler lines, and jacked the front of the engine 2.5 inches to get the clearance I needed. It was still a mission to get the header in place and that's the easy side! The oil filter has about a 2mm gap from one of the header tubes so I plan to put a ding in that tube to gain more clearance and also wrap the oil filter in heatshield material I have ordered. I will also attach some heat shielding to a section of the front end that is too close to a header pipe because it is painted and may well burn if left alone. Now onto the hard side!!!!!
Old Jun 6, 2024 | 05:20 PM
  #34
That's pretty much normal for every set of Olds headers I've ever installed. Correctly designed full length headers are a challenge to design in a way that routes the tubes around all obstacles while maintaining close to equal primary tube length. Of course it is a challenge to install them. Sorry if you didn't realize that, but that's reality. There's a reason why the factory uses small, restrictive manifolds.
aribera94
Sep 14, 2014 04:15 PM
yankees
Aug 25, 2013 07:03 PM
JSGD1966
Oct 14, 2008 10:25 AM
JSGD1966
Aug 27, 2008 07:46 PM
spikey0922
Jan 11, 2003 11:31 PM
