HELP! lol.
Old Feb 23, 2012 | 08:13 AM
blleach's Avatar
HELP! lol.
Getting ready to change all the fluids in my 70 cutlass supreme but, can't find the OE recommendations or the amounts. Can someone either tell me or shoot me in the right direction?
Old Feb 23, 2012 | 08:44 AM
Do you have a copy of the Chassis Service Manual?
If not, you can join Wild About Cars and download a copy for free (the section you need is here), though I always like to have a real one to thumb through as well.
Old Feb 23, 2012 | 11:37 AM
oldsguybry's Avatar
NOVICE car nut
I was just wondering about where I could get a copy of the csm for my car .... thanks Eric
Old Feb 23, 2012 | 12:34 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
The OE recommendations will be somewhat obsolete by today’s standards.
Engine oil = Use something recommended for flat tappet engines such as Shell Rotella "T" I use 15W40 but they make 30, 10W30 & 10W40 too, I think. If you can’t find that several companies are specializing in the correct formula for flat tappet cams of yesterday’s engines or offer an additive. I use ProLong oil additive too. If you have a Shaffer oil distributor in your area use Shaffer. Best oil, grease, etc… I’ve ever used. Pricy though.
Auto Trans = Use Dex/Mercon II or III or Motor Craft Mercon V or TCIs Racing ATF (Jegs or Summit dot com)...good stuff!
Manual Trans grease =???
Brake fluid= Use Dot 3 standard brake fluid. Don’t use synthetic
Coolant = Use the off the shelf 50/50 pre-mixed. Don’t mix tap water with the concentrate only distilled or R.O. water if you choose that route.
Power Steering = Use a good quality off the shelf brand. You’ll need to flush it several times. Use a suction gun or disconnect the return side and run it into a jug for a complete drain.
Rear end juice= Use a good quality grease such as Valvoline 80/90. If it’s a posi put in the GM posi additive.
Old Feb 23, 2012 | 12:57 PM
Originally Posted by blleach
... can't find the OE recommendations or the amounts.
I think he wants to know viscosities and quantities. Those recommendations would be the same now as they were 40 years ago.
1980cutty
Apr 7, 2014 10:47 AM
seventy2cutlass93
Dec 15, 2013 09:10 AM
Kennybill
Ninety-Eight
Jan 28, 2009 03:51 AM
scrappie
Jan 5, 2009 06:07 AM
southcarolina803
Jul 11, 2008 10:58 AM
