Heater core repair for1968 Cutlass S convertible
Last night I got a couple drops of anti-freeze on the passenger side floormat. This is on my 1968 Cutlass S convertible with factory air(that does not not blow cold). The motor is the Rocket 350 2bbl with an automatic transmission on the column. One person told me I would have to drop the right fender well and remove it that way. Does anyone have any suggestions? Thanks, Bill
Just changed one in my '67. I wouldn't think yours would be a lot different. Loosened my inner fender. Loosened all the sheet metal nuts and removed the heater housing under the dash with the heater core attached inside the car. One of the nuts directly behind the fender liner was difficult to get at but with a jointed socket you can do it. Took about 2 hours but I'm a little slow. Have fun. Consult you factory assembly manual and shop manual.
Last edited by tecar442; June 10th, 2013 at 05:48 PM. Reason: more complete answer
heater core
I got home, read your replies and went to work on the Cutlass. I removed the fender well, drained the radiator and removed the top heater hose connected to the heater core nipple coming through the firewall. Ran out of light. Thanks for any more advice you feel would help. I don't have a service manual or anything else so your advice and tips are appreciated. Bill
Hammer7
December 24th, 2013 03:31 PM
