Heater core
Old Nov 24, 2013 | 09:18 AM
Stevec's Avatar
Heater core
Have the engine and trany out of my 68 442 convertible and figured now is a good time to change the heater core instead of getting the car back together and then deal with a leaking heater core down the road.
What's the easiest way to swap out the cores?
Old Nov 24, 2013 | 09:26 AM
The heater core comes out through the interior of the car. So it makes no difference when you change it.
Rob explained his replacement pretty well in this post:
https://classicoldsmobile.com/forums...placement.html
Old Nov 24, 2013 | 01:44 PM
Well, except for the fact that nearly all of the fasteners you need to remove are accessed from the engine side of the firewall.
Old Nov 24, 2013 | 01:49 PM
Napoleon1991's Avatar
I found the easiest way to replace the heater core on my 69 was from inder the hood.
Old Nov 24, 2013 | 01:55 PM
True, but it's the wheel well that's in the way of 1 fastener, not the engine. All the other fasteners are not that bad to access.
Old Nov 24, 2013 | 06:50 PM
Yep, I didn't put that one back on after the first heater core replacement in the '80s and I am sure glad I did it that way!
Old Nov 24, 2013 | 07:17 PM
Me either Ken, it really wasn't needed anyway.
Old Nov 26, 2013 | 06:36 PM
68conv455's Avatar
I pulled the inner plastic fender to better access the retaining nuts. With the engine and trans out, you may not need to do this. If you blower motor is weak, this is a good time to replace it as well. Also a good time to make sure all the doors in you air plenum operate smoothly. Make sure you have some strip caulk on hand to re-seal if you take things apart to clean them up.
Old Nov 26, 2013 | 06:40 PM
Stevec's Avatar
Thanks guys!
Old Mar 17, 2014 | 04:36 PM
atkinsom's Avatar
I have a 1969 Cutlass S that came with factory A/C but is now a delete item in the engine bay...the motor is out for work and I thought it's a good time to get at the heater core with the engine bay empty. I've never done this before and the CSM has vague info to me in regards to removal of the heater core. I've read Rob's howto on the removal from a 72 A/C model...does the same apply to a 1969 A/C model year? Can I remove the heater core from the firewall side without removing the whole assembly under the dash? Looking for the least painful way if there is one for a 1969 Thanks.
Old Mar 18, 2014 | 07:49 AM
There is only one way and it is painful. The 1968-72 A/C cars are all the same (and yours is an A/C car as far as the heater is concerned). The heater core is physically located in the box under the dash and needs to come out from under the dash, HOWEVER, the fasteners for this box are studs that pass through the firewall with nuts on the engine side of the firewall. Some of these nuts are up under the fender, outboard of the heater motor. At a minimum you need to remove the inner fender for access.
Old Mar 18, 2014 | 09:08 AM
atkinsom's Avatar
OK thanks Joe...I guess this will become a maw job
5998DownUnder
Jun 9, 2014 09:35 AM
Redog
Nov 15, 2006 05:20 AM
tarps3
Ninety-Eight
Oct 20, 2006 06:24 AM
<gerardtsr@aol.com>
Dec 17, 2004 04:46 AM
Chris L.
May 28, 2004 09:44 AM
