heater box insulation
Old Nov 11, 2014 | 11:00 AM
pfriesen's Avatar
I'm replacing the heater core on my 1966 Olds Ninety Eight. It had a felt-like insulation between it and the firewall, that's all soaked in coolant, and a bit torn up now. What do you use as a replacement? Can't seem to find the same thing from any of my usual sources (USA Parts Supply, Fusick, Year One)???
Old Nov 11, 2014 | 11:26 AM
RandyS's Avatar
Have you tried your local parts house? If you can't locate one, you can use ribbon caulk to create your own gasket.
Old Nov 11, 2014 | 11:41 AM
pfriesen's Avatar
Tried Piston Ring and a performance shop, both said part is discontinued. That self-made gasket stuff is so different from what was originally there, I'm just not sure. It was a thick felt-like pad that covered almost the entire heater box. 99% sure it was original. I see Year One offers a "heater to firewall seal" for a 1960s Cutlass, described as a "white rope caulk sealant" that comes in a 30-foot roll. That sound usable, or is there something else out there I haven't been able to find?
Old Nov 11, 2014 | 01:52 PM
RandyS's Avatar
Yes, that is the stuff I was referring to.
cutlasssupreme71
Jan 24, 2010 12:07 PM
44TEETWO
Aug 29, 2009 02:47 PM
jeffs 89 cutlass salon
Oct 22, 2007 12:46 PM
Oct 10, 2007 05:34 PM
DJMatthews
Jan 26, 2007 05:59 AM
