Heater Box Correct Gaskets
Old Jul 25, 2017 | 05:51 PM
jdana24's Avatar
1968 Olds Cutlass S
For my 1968 Olds Cutlass S I'm wondering which are the correct gaskets for putting back my heater core since the Service Manual doesn't specify except for saying to put a bead of sealer on the heater box.
Fusick shows the below 5 piece set
http://www.fusickautomotiveproducts....?number=HBG642
OPGI shows the below kit:
https://www.opgi.com/cutlass/CH17264/
And Inline tube shows the items which are sold separately (see photos).
Also, I've read that some people have used a seam sealer on the heater box when putting it back on the firewall, and some have used 3M Strip Calk. Inline Tube sells a white rope caulk but that doesn't seem correct since everything is black and I've never seen a photo of a car with a white sealant around the heater box.
Can anyone shed some light on what is factory correct?
File Type: png
Old Jul 27, 2017 | 01:06 PM
Seff's Avatar
I have no idea what the product is called - but both my 71 and 72 had the thick putty-like filler that's also used behind the kick panels to make them waterproof.
Having googled Strip Caulk, it sounds similar in application to the factory solution.
Old Jul 28, 2017 | 08:42 PM
jdana24's Avatar
1968 Olds Cutlass S
Yes, I have a box of the 3M Strip Calk which I will use to seal the heater box to the firewall and on the interior box. Just wondering whether the Fusick, or the ILT was the correct foam gaskets.
Old Jul 31, 2017 | 08:35 PM
70Post's Avatar
Those are "urban myth" parts (ie - never used on the original cars but now made in an attempt to get more $ from you).
The only "seal", "gasket", etc was a thick/dense foam block that slipped over the two heater core outlets before the INTERIOR box is pushed up against the firewall pad.....this foam block was used to keep hot engine compartment air, etc from coming in through the two heater core pipe holes in the firewall and maybe prevent rubbing/chafing on the two pipes.
Ames Performance Engineering (Pontiac repro parts vendor) makes a very nice duplicate of this foam block (Part # P120M - $12 in their GTO/Lemans/Tempest catalog).
Use the 3M strip chaulk b/n the metal blower motor case and the firewall (engine compartment side). The firewall pad itself serves as a gasket/seal on the interior side of the firewall.
Old Jul 31, 2017 | 08:57 PM
Junkman's Avatar
I used some of the new 3M strip caulk on the back of some moldings where the pins went through the sheet metal, and is attached with stamped nuts. On one, I needed to remove it a few weeks later, and it was just about impossible to get it loose. The caulk was more like a rubber glue that held the molding to the car without even needing the retaining nuts. I have since done some additional "testing" with the 3M caulk, and have determined that at some time in the recent production, they have changed the formula, and it doesn't work like what was available in early 2000. It is a great sealant, but only use it where you are unlikely to ever take it apart again, unless you want to spend hours trying to cut it apart.
Old Aug 2, 2017 | 08:00 PM
jdana24's Avatar
1968 Olds Cutlass S
Thanks for your input Junkman. My 3M Strip Calk is about 7 years old and must be the old formula since where I have used it previously it is still pliable. And like most who have bought this product, I still have about 58' of the 60' that I bought.
Old Aug 20, 2017 | 05:24 AM
rickbmac's Avatar
Was there sealant or possibly a gasket between the blower motor itself and the box that attaches to firewall?
Old Aug 20, 2017 | 12:38 PM
Seff's Avatar
I haven't seen one on my two cars.
Old Aug 20, 2017 | 08:15 PM
steverw's Avatar
I have never seen a gasket or sealant on the blower motor.
Kennybill
Jul 17, 2017 06:28 AM
c-towndave
May 3, 2015 07:55 PM
blunce
Sep 18, 2014 08:49 AM
craftsman1956
Nov 3, 2011 05:00 PM
oldzy
Mar 24, 2010 05:27 PM
