Glove Box Lock 71 Cutlass
Old Nov 7, 2012 | 02:31 PM
cutlass12's Avatar
Can anyone tell me how to remove the lock on the glove box in a 71 Cutlass?
Mine is loose and will spine completely around!!
Old Nov 7, 2012 | 03:05 PM
RetroRanger's Avatar
72 Olds CS
there is a little hole on the lock mechanism on the inside of the glove door near where the mechanism latches. you insert a pin in there to release it
mdchanic (eric) has posted a pic on here somewhere (search) of the exact location the pic appeared to be from the CSM
Old Nov 8, 2012 | 04:45 PM
cutlass12's Avatar
cutlass glove box lock
Thanks, I'll check it out Friday.
Old Nov 8, 2012 | 05:49 PM
72 Olds CS
this wasnt what I was thinking about but its better it shows the actual lock mechanism
https://classicoldsmobile.com/forums...tml#post467725
Old Nov 10, 2012 | 02:17 PM
cutlass12's Avatar
Thanks Retro, things work pretty well when you know how. The nut was unscrewed..
goldie442
Aug 21, 2015 11:01 AM
rmoths
Nov 29, 2012 07:50 AM
spate51
Mar 16, 2012 01:56 PM
yeahbuddy
Sep 21, 2010 02:42 PM
Kidcutty
Jun 13, 2010 07:12 AM
