Gas gauge not reading correctly
I just replaced gas tank, sending unit, sending unit wire and all gas lines but the gas reading drops way below what's in the tank as I drive it. Example it read 1/4 of a tank but I could only put 1/2 a tank of gas back into it. Could it be a short? could it be a bad ground? Is it my gauge? It's a 68 442 conv. Your help is appreciated.
With the key in the "on" position, if you remove the wire from the sender it should go past the full mark. If you ground that wire it will go to Empty. If both actions get these results then your sending unit is not adjusted properly. If not, then your problem is with the gauge or the power supplied to it.
With the key in on position, if you remove the wire from the sender it should go past the full mark. If you ground that wire it will go to Empty. If both actions get these results then your sending unit is not adjusted properly. If not, then your problem is with the gauge or the power supplied to it.
We need a little more info here. What happens when you fill the tank? Does the gauge go to F? Past it? Not quite up to it? The fact that your gauge moves as the fuel level changes, even if it isn't accurate, suggests that the wiring is not a problem. You could do the tests that oldcutlass indicates to verify that your dash gauge is moving freely between E and F and not getting hung up somewhere.
I doubt very much that the float is the problem or that adjusting it, assuming it can be adjusted, would do much good. Adjusting it would be difficult because you have no real way to test its operation without reinstalling everything, and having to drain the tank, remove it, make the adjustment, reinstall the tank, and refill with gas over and over again as you make each adjustment is just not practical.
Keep in mind, too, that fuel gauges are and were rarely perfect. I don't think I've ever had car where the gauge stopped right on top of the F when the tank was filled. It'll usually go past the F. On my '73 Olds wagon, the gauge is "offset" by one hashmark. That means that, when full, the gauge is pointing about one hash-mark's worth past the F. When the tank is half full, the gauge is pointing at 3/4. When the tank is nearly empty, the gauge points at about 1/4. I know this, and I live with it just fine. I just need an indication of the amount of gas in the tank, and I have it. It certainly not worth the trouble of removing the tank and trying to make any adjustments.
I just recently bought a 2014 Mazda 6. The fuel gauge on this car isn't even a needle. It's a semi-circular row of LED's that lights up, with the entire series lit when full and one at a time going out as the fuel is used up. The times they are a changin'!
Unfortunately you will need to take the tank back down.
Yes, the sending unit can be crudely adjusted, as the Professur stated similarly to the arm on a toilet float. To test I just extend the feed and ground wire and test with the tank on the ground under the car.
As Jaunty stated, the gauges can be fairly inaccurate as for determining the exact level of fuel remaining due to the shape and angle of fuel tanks. Mine will tell me when it's full and when it's empty, anything in between is judged by the needle moving back and forth while I'm driving, then I know there is fuel in it. I generally fill it when it drops below a 1/2.
The key needs to be in the "on or run" position. The gauge has 12v on it at all times, the sending unit is a rheostat that basically is giving resistance variations of the ground side of the gauge. It will register from 0-90 ohms depending on fuel level.
OK, with the key in the "ON" position I grounded the wire coming from the sending unit and the gauge went slightly over the "HOT" but when grounding the tan wire coming in from the wiring harness the needle dropped just slightly under the half tank mark. What does this indicate?
I read everything, it's an idiot light gauge therefore the needle can go past the "F" mark (which it does) and it stops at about 2MM past the "HOT" on the idiot light gauge, when shorting the wire coming from the gauge the needle drops slightly below the "half tank" mark. I can take pictures of it.
Okay, you should not be shorting anything.
The sender, as stated in the links above, has a 0-90Ω rheostat, which is connected to ground.
It puts a resistance between zero (direct connection) and 90Ω in the sender line between the gauge sender terminal and ground.
If you disconnect the sender wire, the gauge needle should go past F as far as it can get.
If you ground the sender wire, the gauge should go to E.
If you are grounding the sender wire and the needle is only going to to the half-tank level, the next thing I would do would be to ground the sender terminal at the back of the gauge, and also check that the gauge is getting a full 12V, and that it is well grounded.
If you do all of this, and the gauge still reads half full when the sender lead is grounded, then the problem is in the gauge.
Do you recall what color is the wire of sender terminal at the back of the gauge? I hate the uncomfortable position that we need to be in order to check the back of the gauges! Thanks for all your help.
It sounds as if you have an additional resistance in the wiring between wherever you are grounding the wire and the gauge (or within the gauge itself?)
the tan wire is for fuel pink for 12volt that is correct. You need a good meter to check your ohm reading prefer a digital unit you can check all this without removing tank but if you need to adjust well you do
C'mon, he didn't say this, and it's not that hard to figure out what he means. The gauge cluster is ROUND. The gas gauge part occupies the top portion, between about 10:30 and 1:30 on the clock face, with the F being at 1:30. The HOT light is at about 2:30, and the other lights, for GEN, OIL, and BRAKE are scattered the rest of the way around.
See the image below:
![](http://www.oldsobsolete.com/wp-content/uploads/2011/06/DSCN4316.jpg)
With the wire from the sending unit to the gauge separated at the connector (open circuit), the needle moves well past the F on the gas gauge portion of the dial all the way over to where the HOT indicator light is because it's reading infinite resistance, which is way more than 90 ohms, which is the resistance corresponding to F on the gauge.
This, boys and girls, is how fuel gauge can read HOT!
P. S. I've seen gas gauges over the years with a little post sticking out just past the F to prevent the needle from going too far past it. That's actually unfortunate as it prevents the gauge from acting as a diagnostic tool to troubleshoot a fuel gauge problem.
All well and good, Jaunty, but not everybody has a Cutlass from this year range, with this gauge and light layout.
I figured out what he meant, but, in general, it is less than helpful when posters assume that all of us can see exactly what they're looking at, and therefore fail to properly describe what they are seeing.
The fuel gauge on my 67 is a little rectangle and is in no way near the hot light , and yes initially I got confused as couldn't figure out what he said. I got it after reading all the other links Eric posted.
GM has used this same style gauge operation from 1965-1990, it's not difficult to trouble shoot.
Hopefully the OP has it figured out.
I used the volt meter to see the current coming in and the tan wire going to the sending unit as 9 to 9.5 volts on it and the back lights have 13 volts coming in. Is this any indication?
It's not a short. Your gauge would be reading empty all the time if your sending unit wiring were shorted, and it would be reading F or well past it if the ground were bad.
#32
I've never used a meter to troubleshoot a fuel gauge circuit. If your on the terminal that the sender wire is attached to, then your reading voltage that's coming through the gauge on the negative side. So yes, there will be a voltage drop due to what ever resistance is in the gauge.
Did you ground the tan wire side of the gauge, and did it go to empty?
jpaulwhite
June 26th, 2012 02:59 PM
