Front springs 70 Vista Cruiser
Old Jan 24, 2015 | 06:37 AM
So farI haven't been able to find specific front springs for my Vista Beater. Rock Auto, Moog, and other sites don't have a listing. I attempted to order a set earlier and the local parts store couldn't find a specific listing either. He talked with the Badgleys (local Olds experts) and they thought that probably a set for a Cutlass/442 w/air would be a good fit. I tend to agree but not sure. My car is a 350 w/air. I'm sure that the Vista Cruiser is the heaviest A body. I am thinking about ordering some springs for a Cutlass/442 455 w/air. I'm guessing those would be the heaviest. I don't want to lower the car, actually a little higher would be good for me. What have you guys done? Thanks, Greg
Old Jan 24, 2015 | 08:03 AM
If you look up the actual specs of your springs including the end types. You can use this chart to cross something that will work.
http://www.moog-suspension-parts.com...il_Springs.asp
Old Jan 24, 2015 | 08:28 AM
montvaleplace's Avatar
I used 1970 442 455 with air on my 70 vista and the height looks stock. My motor is a diesel converted stroker, M20, with vintage air and ss1 15" rims.
Old Jan 24, 2015 | 09:14 AM
That's because from the firewall forward your car is a Cutlass. Get Cutlass springs for the same engine and equipment.
Old Jan 24, 2015 | 09:59 AM
Tony, that thing sounds awesome. Seems like a good plan on the springs.
Old Jan 25, 2015 | 07:27 PM
Mr Shifty Sidney's Avatar
Greg
The assembly manual has a table showing each series with option combos, this table list spring rates. You can use this to match up to your Vista.
Don W
Old Jan 27, 2015 | 03:37 PM
Originally Posted by Mr Shifty Sidney
Greg
Don W
Thanks, Don. Yep I found the original Gm part # and put it in to RockAuto and came up w/ Moog 5400. I already received them. Back to work again!
Old Jan 27, 2015 | 07:01 PM
Glad to help. Good luck with your front end rebuild.
Don W
DennisG.
Vista Cruiser & Wagons
46
Jan 19, 2022 01:22 PM
MudEye
Oct 22, 2013 08:32 AM
1acesmith
Aug 11, 2011 11:03 AM
Bobac455
Jul 31, 2010 10:26 AM
WTony
Jul 3, 2010 10:48 AM
