fresh 455 overheating on the highway
Old Jul 10, 2016 | 02:48 PM
72.442.Tulsa's Avatar
442 Chris
I just spent the last year upgrading to a rebuilt 1969 Olds 455 with a TH400. Car runs like a scalded ape, but on the highway running 3500 rpm going 70mph the the temp gauges goes dangerously high. back it down to 55mph and the gauge drops where it should be. I have a new 3 row aluminum radiator that is supposed to be good up to 500hp. I was thinking of drilling a couple holes in the thermostat to increase flow at high rpm. Any thoughts or suggestions would be greatly appreciated.
7/9/2016
Old Jul 10, 2016 | 03:56 PM
What temp is it reaching?
Old Jul 10, 2016 | 05:05 PM
My car acts similarly on the highway when I have the AC on and it's 110+ outside. The temp will creep up into the 210+ range when the engine is over 3200 RPM and will drop back to 190-200 if I back off to under ~2800 RPM.
I think the issue is that the cooling system can't dissipate as much heat as the engine is making at the higher RPM. I have a 4-row copper-brass radiator and it works well enough that I just drive slower on the highway during the summer. I don't think drilling holes into the thermostat will help, but a high flow thermostat would probably be a better option. I don't know if that will be enough to cure the issue, though.
Old Jul 10, 2016 | 05:17 PM
jaunty75's Avatar
This is nothing wrong with this temperature, and it is not the indication of an overheating engine. Your engine could run all day long at this temperature with no problems at all. It would be more efficient, and you'd likely get a tiny bit better gas mileage.
Old Jul 10, 2016 | 05:18 PM
jaunty75's Avatar
Define "dangerously high."
Old Jul 10, 2016 | 05:26 PM
I agree but I should also say I never tried to see how high it would go; I always back off the RPM when the temp gets to 220. It is possible it would go even higher but I have no desire to verify that.
87wagon
Apr 18, 2012 11:45 AM
Dec 10, 2011 07:49 AM
cnewp000
May 28, 2010 05:55 AM
AZ442
Oct 31, 2009 05:06 PM
gillbates
Sep 18, 2009 10:57 AM
