fan clutch question
Old Mar 20, 2014 | 10:58 AM
foo's Avatar
foo
fan clutch question
Are fan clutches only used on cars with AC?
Im trying to figure out if I go with them or just a bolt on fan.
Old Mar 20, 2014 | 11:17 AM
brown7373's Avatar
Clutch fans and 6 or 7 blade fans are always found on A/C cars, and on some non A/C cars. They provide more airflow and better cooling.
Old Mar 20, 2014 | 12:58 PM
mrolds69's Avatar
If you ordered HD cooling on say a 1969 442 it would have had a clutch fan AND SHROUD. Shroud is the key word here, w/o that you are wasting your time and could actually make the cooling worse.
Old Mar 20, 2014 | 02:46 PM
BlackGold's Avatar
Another important distinction is that, when a fan clutch was installed by the factory, they also installed pulleys which overdrive the water pump, meaning the pump spins faster than the crank. Cars without a fan clutch used pulleys which underdrive the pump.
The reason for overdriving the pump is twofold: First, since these applications by definition needed more cooling, the engineers wanted to push more coolant through the engine. Second, at idle and low rpms, the fan spins slower with a clutch, so the engineers wanted to compensate and speed it up again.
Old Mar 20, 2014 | 03:08 PM
RROLDSX's Avatar
You guys are amazing... is the shroud and rad the same for each type of fan?
Old Apr 1, 2014 | 05:22 PM
foo's Avatar
foo
Just getting back on to this, so what you're saying in that the bigger pulley (which is what i have) would be for a fan without clutch?
Old Apr 1, 2014 | 08:26 PM
mrolds69's Avatar
You need to know what you have now and what you should have. Like my 67 GS400 had a clutch fan, no shroud and AC pulleys on it when I bought it. It ran hot. I changed it to the right pulleys, a FOUR blade correct fan, no shroud and it runs perfect! If you say what combo you have (1970 Cutlass 350 w/o AC for ex.) Somebody here can tell you what it was or should be. Then...you go from there.
Old Apr 2, 2014 | 01:02 AM
foo's Avatar
foo
the engine is going into my 70 442, 455 w/o AC, w/ PS, unknown if i even have a shroud, engine was out of a car when i got it.
Some of my concerns/ questions are;
Im trying to get the correct setup for the car
-Do I need the clutch fan set up or just the bolt on and spacer?
RandyS
Jul 6, 2021 07:45 PM
47 Convertible
Apr 3, 2014 07:56 AM
RandyS
Mar 8, 2014 05:07 AM
agtw31
Jun 23, 2009 01:39 PM
esisson
May 20, 2008 12:09 PM
