Engine questions for new 72 Cutlass
Old Apr 5, 2009 | 03:06 PM
B-Mann's Avatar
Hi guys, I'm new to the site and just recently bought a 72 Cutlass S. The engine seems to have a miss in it and if you unplug one certain plug wire it idles fine. Any ideas what might be the issue with it? Thanks for your help.
Old Apr 5, 2009 | 09:23 PM
mugzilla's Avatar
is Fast Enough ...
Look under the hood at night and see if there are any flashes of light ...
Old Apr 6, 2009 | 04:30 AM
Welcome
Welcome aboard
Tell us a litle about your car.
And please post pics
Old Apr 6, 2009 | 05:41 AM
csstrux's Avatar
X2 Sounds like a short, likely bad wires. You will probably want to go the whole nine yards, and replace plugs wires cap rotor, points and condenser. At least that is what I have done in the past. That way I KNOW everything is done, and should expect it to last. I am kind of lazy though, and don't like tearing into the same things repeatedly
Old Apr 6, 2009 | 07:07 AM
citcapp's Avatar
Welcome to the site. I agree with replacing the plug wire it sounds like they are cross firing. this happens when the wires are old.
Old Apr 6, 2009 | 03:41 PM
74Cutlass S's Avatar
When I got my 76 chevy pu, i had the same problem, replaced plugs, wires, dist cap and that took care of my problem
Old Apr 7, 2009 | 03:14 AM
Yellowstatue's Avatar
Smile Miss or Mrs.
I was thinking two of his plug wires are switched around...idles smoother??
Old Apr 7, 2009 | 04:52 AM
68ragtop's Avatar
I have seen this happen with a bad cap too. Its either cracked or arcing between poles inside.
Old Apr 7, 2009 | 12:24 PM
B-Mann's Avatar
I bought new plugs wires and cap, I will install them tonight and let you guys know if it helped. I don't know how to post images on here yet so if someone could let me know I will post pics of car. Thanks
Old Apr 7, 2009 | 05:55 PM
B-Mann's Avatar
Old Apr 8, 2009 | 02:45 AM
Thumbs up Sweet
Well it appears you figgered out how to post pics.
Wow, beautimous car.
What's in the lower left hand corner?
Old Apr 9, 2009 | 12:25 PM
B-Mann's Avatar
I'm not sure that picture is the picture that the guy i bought it off of sent to me. Does anyone know where the bolts are to remove the back seat on the 72 Cutlass??
Old Apr 9, 2009 | 02:58 PM
citcapp's Avatar
Unusual color but I like it. Nice car
Old Apr 9, 2009 | 03:11 PM
68Tom's Avatar
The back seat? Well, you should be simply able to lift the front end of the rear seat bottom cushion up towards the back of it. Sort of push in and up. Then, the seat back will have one bolt on either side at the bottom bolting down the seat back cushion frame. After the bolts are removed, you have to lift the seat in an upwards motion (towards the roof) to get it to unhook at the top.
Hopefully this makes sense. In my mind, it's very simple. Typing it out, not so much.
Old Apr 10, 2009 | 03:19 AM
Smile Cushy
Don't forget to remove the arm rests first...
ah64pilot
Sep 19, 2012 10:55 AM
ah64pilot
Aug 17, 2012 02:36 PM
805cut
May 3, 2012 08:11 PM
HAFROD
Feb 8, 2008 09:33 PM
carmine615
Jan 13, 2008 05:07 PM
