Engine codes
That number is the VIN derivative of the car the engine came from.
3 = GM division = Oldsmobile
8 = model year = 1968
1 = assembly plant = Oshawa Canada
130833 = plant sequential number
The casting number (and letter) for the engine block is located on the front of the engine block, visible from the top, between the intacke manifold and the timing cover.
Randy C.
Randy C.
Ok so ive been looking at all these threads and cant seem to know what engine i have three codes all point to a 350 but ive never seen anybody ask about all three only one...
1.Driver side#39M421187
2.oil tube#9654555
3.right behind timing plate 395558 big 2
And i have the number 5 heads
Gold block
2.oil tube#9654555
Gold block
Codes
2.oil tube#9654555
Gold block
2.oil tube#9654555
Gold block
1) same as what Randy posted above, 3(olds)9(1969)M(Lansing) 421187 is the VIN derivative and should match the last 6 numerals of your cars VIN tag.
2) 9 (1969) 654555 is the engine plant sequence number...means something to the engine plant but no one else
3) confirms its a 350 block.
Brett
