duel point distributor w/ mechanical tach drive
I have acquired a duel point distributor w/ mechanical tach drive I removed from what I think may have been a marine 455. Is this a rare or collectible item? I don't want to use it, as I have no use for the tach drive. If its not valuable I was thinking about cutting it up to make a oil pump priming tool. Thoughts?
I have a couple tach drive Oldsmobile distributors. I advertised them on this site and racing junk and never any interest.
You could try ebay??
The olds oil pump is driven by a hex shaft so a socket secured , taped on an extension , so it does not fall off works well. The hex drive is in the distributor gear SO you would have to remove all the teeth to clear the camshaft , Very different compared to a chevy V8
To answer 70W-32 there was no numbers or markings of any kind so I don't know what brand it was. Today I ground off the gear teeth and cut off some of the aluminum housing on top. Welded on a threaded rod coupling ( 2 inch long nut) onto the shaft. Makes a nice priming tool...and no chance of dropping a socket into the motor. Also keeps the shaft perfectly straight and centered so no unnecessary abuse to the driveshaft and oil pump. Not that that is likely an issue.
Big Daddy Spo
July 6th, 2021 02:20 PM
