Driveshaft length
Old Dec 12, 2022 | 06:09 AM
Steve13's Avatar
Steve13
Driveshaft length
I have a 69 olds f85 3 speed it has the Dearborn transmission in it . I do not have the drive shaft for the car I've been looking for information on how long it is and where I can find one I can get one made I just need to know what the length is from u joint to new joint if anybody knows would be helpful
Old Dec 12, 2022 | 07:31 AM
You should probably start your own thread, Steve. This one's 8 1/2 years old.
Old Dec 12, 2022 | 08:05 AM
The easiest thing to do is to measure your car for a custom-made driveshaft. Raise the car with the suspension at ride height (ie, jack stands under the suspension, or use a four post lift). Push the front yoke all the way into the trans until it bottoms. Pull it out one inch. Now measure center-to-center distance between the front and rear yokes. This is the dimension the shop needs to build a new shaft.
Old Dec 12, 2022 | 02:47 PM
83hurstguy's Avatar
Nobody wants to do it the way Joe described above because of the effort, but it's the right way. New yokes have different lengths than the originals (and can vary), so you don't want to rely on factory data or other people's u-joint center to center lengths. Get the yoke you need, take the measurement, get the shaft made.
Old Dec 12, 2022 | 06:20 PM
Loaded68W34's Avatar
Visit the PST website:
https://pstds.com/
They can make you a custom driveshaft with a yoke for a reasonable price. You will need to get the rear end at ride hieght as said above, but from there you can measure from the trans tail shaft yoke seal to the rear u-joint center line or even the rear end pinon seal if you plan to buy a pinion yoke from them as well. They made the 4" aluminum driveshaft for my vista cruiser. I bought front and rear yokes so I measured seal to seal. Very good customer service. If you give them a call they can get you squared away with the proper shaft diameter and material for whatever you are trying to acomplish.
WTHIRTY1
Jun 3, 2021 09:12 PM
scrappie
Feb 9, 2018 06:27 PM
Xlhowie
Drivetrain/Differentials
Apr 6, 2016 08:06 AM
HotBoy RuNNA
Aug 5, 2011 12:28 PM
scubastever
Jan 13, 2010 09:21 AM
