Diff pics for Id help
Old Jun 23, 2012 | 05:49 AM
boese1978's Avatar
Any help id'ing my rear end would be appreciated...the numbers in the pic are 358, it is in a '68 cutlass convertible, 12 bolt, type "O". I found no numbers on the axel tubes. The diff housing has the casting number - 394139. Thanks for the help!!
Old Jun 23, 2012 | 06:28 AM
sparkymark's Avatar
gears
should be numbers on side of ring gear. got picts?
Old Jun 23, 2012 | 06:42 AM
boese1978's Avatar
I don't see any numbers anywhere else......
Old Jun 23, 2012 | 10:29 AM
sparkymark's Avatar
gears
should be on the side near where the gear bolts to the ring
Old Jun 23, 2012 | 10:33 AM
sparkymark's Avatar
gears
also you can check pass.side axle tubein rear next to housing should be two letter like TO
Old Jun 23, 2012 | 11:37 AM
boese1978's Avatar
I ended up counting the teeth on the two gears and devided them into each other to come up with a 2.78.....
68oldscutlass
Drivetrain/Differentials
Mar 28, 2013 09:29 AM
62radarlove
Jun 2, 2012 09:16 AM
rsandhoff
Apr 8, 2007 06:02 PM
77supreme
Mar 12, 2007 03:42 PM
hubb
Aug 10, 2003 10:12 PM
