Decoding Starter Stamping
Per the attached image, I have a starter with the following stamped on one end:
1998590 9 K 5 2
Also a "B" is stamped on the cylindrical body of the unit.
Any help with decoding this would be greatly appreciated.
Thanks.
1998590 9 K 5 2
Thanks.
Chevy 1989 October 5th. If it is still original it should have a drive end housing that has the staggered bolt pattern with 10MM mounting holes. The opening in the drive end housing will be a small square .
