Dash pot
Old Apr 19, 2017 | 06:26 PM
Rick P's Avatar
Dash pot
I need a dash pot for a 70 cutlass with a 2barrel. Anybody make them? What it does is when i'm at a light for awhile, It just dies. Then of course it hard to start.
Old Apr 20, 2017 | 07:31 AM
friesjh's Avatar
Please someone correct me if I'm wrong, but I do not believe the dashpot is your problem. Sounds like more of a carburetor issue.
Old Apr 20, 2017 | 08:17 AM
jensenracing77's Avatar
The dashpot is to prevent the throttle blades from closing all the way to fast. If your problem is when sitting then the dash pot is not the problem.
Old Apr 20, 2017 | 11:32 AM
Tedd Thompson's Avatar
Could be many things but air leak somewhere in the fuel line system seems possible or a fuel pump valve that is going bad.You really need to do some investigation before we can help. Have you taken off the air cleaner and checked to see if there is fuel in the carb bowl( pump the throttle to see if the accelerator pump has fuel to it).You need to sort out whether it's fuel related (probably) or something else.... Tedd
Old Apr 20, 2017 | 01:21 PM
Rick P's Avatar
Ok, I'll look into it further. Thanks for responding.
Old Apr 20, 2017 | 07:40 PM
Quadrajet Power's Avatar
Dashpots to my knowledge are no longer being produced. You would have to find a NOS unit.
Old Apr 21, 2017 | 07:49 AM
I don't think a dash pot does do much more than slow down the linkage to the carb on deceleration. It was the first of the steps the car company's did to help emissions.Could be wrong on this, all my cars are ether old enough to be emission free or fuel injected.... Tedd
Pacecar
Aug 7, 2012 07:03 PM
harleyrules
Aug 22, 2011 08:24 PM
fjross
Dec 19, 2009 07:17 AM
70-442-455
Jul 28, 2008 09:23 PM
dynamic88
Jul 30, 2007 05:39 PM
