Crankshaft
Old Feb 21, 2014 | 12:52 AM
RonzBoyz4's Avatar
Crankshaft
Team,
I am putting my stuff on my motor. After torqueing the main crank caps, I have "play" on the crank. I noticed it when I picked up on the crank shaft to reposition the engine.
How much distance/clearance should there be on the main caps to the crank?
Thanks,
Bearing Set
SLP-4281M
---- Engine ----
1968
350
Block# 395558 2
I found:
.0004 - 0021
# 5 .0015 - 0031
Old Feb 21, 2014 | 06:18 AM
cutlassefi's Avatar
Originally Posted by RonzBoyz4
Team,
Thanks,
Bearing Set
SLP-4281M
---- Engine ----
1968
350
Block# 395558 2
I found:
.0004 - 0021
# 5 .0015 - 0031
I'm not sure how you can feel play with those tight clearances. Less than a half thousandths on a main will almost guarantee a spun bearing.
Old Feb 24, 2014 | 06:58 AM
RonzBoyz4's Avatar
1968 Crankshaft
So, I came to the conclusion, the crank must have been turned, at least once, in the last 45 years....
When my plastigauge arrives, I will see just how much and order the correct bearings....
Anyone need a set of new bearings?
http://www.oldsmobility.com/old/enginespecs.htm#Crankshaft_Bearing_Journal_Specifi cations
sssingo
Nov 9, 2008 03:47 PM
raymondh
Aug 20, 2008 03:45 AM
raymondh
Aug 14, 2008 04:56 PM
poorpea
Jul 13, 2008 06:04 PM
Swed Olds
Jul 26, 2007 02:55 PM
