Correct power steering cap
Old Apr 26, 2016 | 07:15 PM
83hurstguy's Avatar
Does anybody know what the correct power steering cap for '68 A-body with V8 looks like?
The '68-69 parts manual states that it should be part number 5692928, but I can't find any reference pictures of that.
There are two main styles I've seen, shown in pics below... they are either shiny metal with two "ears", or black corrugated plastic. The NOS black plastic one I have has part number 7803820.
Thanks in advance!
Old Apr 27, 2016 | 04:29 AM
I recall seeing the plastic ones on the '68s, and not the metal ones, but that doesn't meant they were correct.
Old Apr 27, 2016 | 10:45 AM
marxjunk's Avatar
Round no ears with a white dip stick is assy line from my experience
Old Apr 27, 2016 | 10:57 AM
83hurstguy's Avatar
Were they black plastic or metal?
Old Apr 27, 2016 | 01:30 PM
marxjunk's Avatar
I've seen both, I have both. But I wasn't smart enough to document dates. I'm going out on a limb and say early is metal, like 67s
I will look at my 68s and see if I can figure it out I have 3 here with power steer
I have no idea where my used ones are...I haven't found them from the move yet
Old Apr 27, 2016 | 03:03 PM
costpenn's Avatar
Luke, I cant 100% guarantee, but I've seen both the metal ear type and plastic types on 68's that I believe to be original:
Metal Type - Chris Dreiling has a mostly original VERY early production Lansing built car (2nd week Sept 67). It also still has those weird headlight bucket gaskets, and the A/C vent in the center of the dash only has one longitudinal rib.
Plastic Type - My Hurst has this, and since just about everything else on the car is original I would believe it would be OE for my car. Obviously it is a late May build - maybe that explains the two listed - metal for the early production, and the plastic for the later ones. Where the change is - does the revision list in the PIM help?
Old Apr 27, 2016 | 03:23 PM
83hurstguy's Avatar
The PIM (6-1, page 126) appears to show the metal two-eared cap on the drawing, but there's no notes I've seen about it, unfortunately. There's a pump assembly number (7801023 for A body), so there is likely another drawing for it somewhere that is lost to the ages... I may check my '69 PIM tonight to see if it has any more info in it, since the '68 manual is a bit thinner on engine info.
Old Apr 27, 2016 | 03:43 PM
Octania's Avatar
As I understand it, from experience, the '67 and earlier pump has the larger opening and takes the larger metal 2-ear cap.
The 1968+ pumps have a much smaller opening and can only use the smaller plastic many-ribbed cap.
I have not looked into whether the pump/bracket assemblies interchange, but I know the whole pulley set including groove to groove spacing for one pair of grooves changed from 67 to 68.
While not impossible, and I have not seen every such car, I think it is unlikely that a '67 came from the factory with the small top pump, or a '68 came with the large-top pump.
Old Apr 27, 2016 | 08:33 PM
83hurstguy's Avatar
I opened my NOS plastic cap tonight, and it replaces with the 2 ear metal cap on my pump without issue (both are made for the same size reservoir neck). Both fluid level sticks are close to the overall same length, but the two ear metal cap says "full" about 1/2-3/4" lower than the plastic cap says "full hot".
I also confirmed that the p/s pump assembly in the '69 PIM is also 7801023 for F-85, though I don't see any details that would pertain to the assembly or the cap.
Thanks for all the input, guys... interesting discussion.
Old Apr 27, 2016 | 09:56 PM
costpenn's Avatar
Luke, what is the date listed on 6-1 126.? Very interesting indeed. Again, I'm about 99 percent sure that Chris's is original to his car with the metal cap with ears - a likely leftover. I wonder what the pump assembly P/N is in the 67 PIM?
Old Apr 28, 2016 | 06:45 AM
83hurstguy's Avatar
My 6-1 126 is dated Nov 11, 1966 for initial issue, with revisions up to K2 on 1-19-68 included.
EDIT: I checked my '68-'69 parts manual (effective Dec. '68), and it agrees with the PIM that 7801023 p/s assembly is correct for '68-69 F85. Per the parts manual, '67 would have 5698090 or 5699490 pump assemblies.
Here's what the parts manual says about caps:
1966-67 V8 P.S ...................................CAP, reservoir (w /gasket).......................3908539 1.50
1966-68 L6 P.S....................................CAP, reservoir (w /indicator).....................5690846 2.00
1968-69 V8 P.S ...................................CAP, reservoir (w/gasket)........................5692928 1.94
1969 L6 P.S ........................................CAP, reservoir.......................................78 03820 2.25
Old Apr 28, 2016 | 07:12 AM
83hurstguy's Avatar
For the record, I started searching p/n's, and found what is claimed to be an NOS 3908539 on ebay (no packaging though). It looks like this:
http://www.ebay.com/itm/NOS-1966-197...JWlFVq&vxp=mtr
It's similar to the metal 2-ear cap I have, mine has an indicator, the one on ebay does not.
Last finding: per this website (http://www.oldsmobility.com/mpc/group6000/text05.htm), which claims to reference the July '72 parts catalog, the '68-70 V8 all used the same cap, which would be black plastic.
6.635 ― CAP, POWER STEERING GEAR OIL PUMP RESERVOIR
7803820 1966-71 ALL 6 CYL- OIL FILLER
3908539
1964-66 ALL V-8 - INCLUDES GASKET [SUP 5695670]
7808942 1968-70 ALL V-8 - INCL GASKETS [SUP 7802636-5692928-7802636]
7803820
1972 ALL - OIL FILLER
Now I'm wondering what the difference would be between the 6 cylinder and V-8 power steering reservoirs, and why the '72-up reservoirs use the same dipstick as '66-'71 6 cylinders... the NOS filler cap I have (7803820) is listed as a 6 cylinder cap or '72-up all per the catalog.
Old Apr 28, 2016 | 07:17 AM
That $125 NOS cap has a distinct ring around the gasket where it never contacted the sealing surface of a P/S reservoir.
Old Apr 28, 2016 | 09:23 AM
rob1960's Avatar
My '68, a Nov '67 Lansing car, has the small metal cap with the ears & a round plastic dip stick inside. It has a natural galvanized type finish just like the one in the engine pic from the '68 dealer brochure. It's much smaller than the '67 style. I've seen both kinds on '68s. My first '68, that I restored back in '78-'80 was an April '68 build & it had the round ribbed plastic cap.
Old Apr 28, 2016 | 09:33 AM
Octania's Avatar
rob,
THANK YOU for the photos. In all my travels I have never noticed a small-dia two-eared early 1968 PS cap. That factory pic has a whole lot of '68-only stuff.
Old Apr 28, 2016 | 09:57 AM
rob1960's Avatar
Octania,your welcome!! don't know why it's sideways?? I flipped it before I uploaded it. You're right about the '68 only stuff in the pic. I've had allot of '68s over the years & I've never seen an oil filler cap like that one. I have the chrome '69 H/O repop cap from Fusick on mine but it's the same as my original painted one that has the "AC FC-60" stamped on it. I've had a couple of very knowledgeable Olds nuts tell me that the alt. fans on '68s were painted black,but the one in the pic is clearly plated.
Old Apr 28, 2016 | 10:31 AM
83hurstguy's Avatar
Interesting, thanks Rob.
I had an original '767 alternator here with '68 date code, and the fan was definitely plated from the factory.
Old Apr 28, 2016 | 11:19 AM
mrolds69's Avatar
I've been watching this thread since it was first posted. I didn't want to say w/o knowing for sure. A couple things...I have a cap removed from a 68 442 a wazillion years ago, it's a small eared natural metal cap. I'm fairly positive a 69 cap is plastic. You can't go by the parts books, some parts were superceded within 6 months. If you look at a 72 or 75 parts book, it will tell you what was available at that time, not the original 68 part, assembly manuals are best for that. I think there was a change even in the plastic caps around 71-72...the lettering or something. You can't really go by factory pics in brochures, stuff was enhanced in those pics and often the engine was from the previous year. That engine pic looks pretty good. Finally...I was recemtly trying to figure out my PS cap for my 67 GS. I spent hours + hours researching. On a camaro website, I found like a 10 page thread about caps, recalls and changes around 67-68.
Old Apr 28, 2016 | 04:04 PM
Thanks, Rob!
I've always liked this photo of the New '68 350, and I've stared at it in the past, trying to pick up on the various details that it shows, but I will admit that I NEVER noticed the metal P/S cap until you pointed it out.
Old Apr 28, 2016 | 06:07 PM
costpenn's Avatar
The pic validates another detail - whether that the P/S pulley nut should be "bright" or not. And it is not just for this publicity photo - the '73 Lansing big car assembly line photos show the same thing. Also, interesting on the stud bolt at the engine lift hook, and you can really see the offset in that water outlet.
Old May 11, 2016 | 10:51 AM
68-W46's Avatar
My 68 has the plastic cap...
Old May 11, 2016 | 04:26 PM
costpenn's Avatar
Here's a pic of Chris D.'s P/S pump assembly off his 2nd week of Sept 67 Lansing built Cutlass S.
File Type: jpeg
Old Nov 19, 2018 | 08:34 AM
Superdutch71's Avatar
Are you still looking for the fitting and cap?
Old Nov 19, 2018 | 09:45 AM
JohnnyBs68S's Avatar
FWIW, my '68 has the metal 2-ear cap, which I know is original. It's a fall '67 Lansing car.
NotDads442
Nov 12, 2018 05:55 AM
72455442RA
Oct 1, 2018 08:35 AM
Bobbity
Sep 25, 2018 06:37 PM
Michael Tolomei
Jun 23, 2018 10:58 PM
mmurphy77
Mar 18, 2011 05:08 AM
