Converting single exhaust to dual '59 98
Old January 11th, 2012, 06:08 PM
JJRitchey's Avatar
My '59 Holiday Coupe (394 cid with a/c) came from the factory with a single exhaust (dual was an available option). I am seriously considering a dual stainless steel replacement system. Is this simply a matter of ordering a dual, and installing or are there other considerations that make this not such a good idea?
JJRitchey is offline
Old January 11th, 2012, 06:20 PM
Oldsmaniac's Avatar
I have duals on my 98. Going from memory if you have the factory 1959 exhaust manifolds you can just order the dual exhaust. There is a blockoff plate required on the end of the manifold on the passenger side if memory serves me right...
Oldsmaniac is offline
Andrew Morris
September 11th, 2012 06:53 AM
65OldsDelta88SuperRocket
October 27th, 2011 09:16 PM
BStone
16
August 12th, 2011 10:17 AM
CutlassLegend
Brakes/Hydraulic Systems
August 7th, 2011 05:15 PM
Dant
June 27th, 2011 01:38 PM
Quick Reply: Converting single exhaust to dual '59 98
