Convertible vs. hardtop glass?
My new '65 convertible doesn't have side glass.
I keep seeing people selling front side glass that will (supposedly) fit both a hard top AND a convertible.
But when I look up the parts they have different #'s
I know the rear is definitely different.
Thanks for any help in ANY convertible vs. hardtop door differences.
-peter
-peter
Peter, I've got the rear glass out from a 1964 hardtop & convertible, here's pictures of them. I do have extra tinted and clear for the backseat. I have doors from both the convertible and hardtop, if nobody can verify if they are different or not I can take some measurements for you.
hartop glass is clear and underneath the tinted convertible glass
Hardtop on left, convertible on right
The metal for the hardtop has a piece broken off at the very bottom
Number on the hardtop glass frame
Number on convertible glass frame
Thank you Blu!
I have the rear glass thankfully.
I thought hardtop front glass would work...but the 1965 Parts master list says they're different.
I have a '64 hardtop parts car I've been hopeful would work.
Have any side picts of convertible front glass?
-peter
-peter
Thing is the door glass is still different between Holiday Coupe and convert.
I’m just happy to hear the vents are the same…on less tricky part.
Joe, do you think the difference between the two could be thickness, or type of safety glass?
Extra layer of lamination or something?
I’m just pulling straws…but wouldn’t they want a convertible’s glass to be a bit stronger with not having a real roof channel to tuck into?
Maybe it’s not the size, but the construction?
Just guessing.
-peter
Just guessing.
-peter
I threw in hard top glass from my 64 just to see if it would work…looks pretty much correct.
Still a mystery why the parts #’s are different.
Curve looks the same.
-peter
-peter
-peter
-peter
I HAVE AN ANSWER!
It is indeed different shaped glass.
The convertible has more of a bow to the top edge and possibly a slightly different angle to the tail edge.
In these pics the convertible glass is underneath with hardtop glass gently laid over the top. (I lined everything up very carefully)
Different part # equals different part(and not just how the glass is tempered.)
-peter
-peter
