changing from a at to a 4sd help
i have a 64 f85 with a330 and a jetaway at im changing to a 4spd i use pedals for a chevelle fit great i got a z bar for a 66-67 cutlas i need the rod from the pedals to the z bar and a flywheel for my 330 i was wondering fi a chevelle rod would work any of you boys in the bad olds world tired
thanks im going to try the chevelle rod i have to find a flywheel next im thing about headers too they make then for a 65 bb but a sb i was thinking maybe 68-72 350 i dont know its not a sb chevy that would be to easy the 330 runs good its got about 87000 on it i would like to see how it runs with a little more cam my 4spd and a set of 355-373 gears
It is non-trivial to get the frame tab into the exact, correct position. There are no easy ways, no alignment holes or nearby holes that help enough. I recommend putting a block, bellhousing, and transmission into the frame with transmission crossmember, and then install the Z bar dead straight up and down, fore and aft, so the tab will be exactly where it belongs. Get a good welder to attach it, too. The tabs are being reproduced, or you can make one if you are very handy and can get the right bends in it.
BB, sure
68-72, sure
No, 68 headers for 350 DO NOT pop right into a 67 with 330.
As for the clutch ROD, sure, the GM A-bodies no doubt all use the same rod. But, if you are into this level of alteration, surely you have a cutoff tool, torch, and welder. ANY rod from any GM truck, or just about anything, can be cut, bent, and welded to suit. For the '69 project I did a while back, the rod I had [came with the pkg] did not fit- hit on the firewall. I drew what I needed on the welding bench and then cut bent and welded until it fit right and worked right.
Richie
February 14th, 2005 02:49 PM
