Big Block on an Engine Stand
Old Feb 22, 2009 | 09:00 AM
sklbndt's Avatar
Am in my first project and have never worked with an engine stand but it just seems to me that it's a lot of load on 4 bolts to hold that big ole 455. Engine stands have been used for decades with little or no redesign so this question is probably kinda silly, but really, 4 bolts into the bell housing and no problem??
Old Feb 22, 2009 | 09:11 AM
Bluevista's Avatar
Registered
Danger-Danger Will Robinson! They don't attach to the bellhousing!!!! If you mean directly to the engine on the back it's a different story. No problems other than making sure it doesn't fall over and use the correct grade bolts. Careful moving one, on a 3 legged stand especially, like this.
Last edited by Bluevista; Feb 22, 2009 at 09:22 AM. Reason: pic of mammoth 350 engine
Old Feb 22, 2009 | 09:20 AM
sklbndt's Avatar
Originally Posted by Bluevista
Danger-Danger Will Robinson! They don't attach to the bellhousing!!!! If you mean directly to the engine on the back it's a different story. No problems other than making sure it doesn't fall over and use the correct grade bolts. Careful moving one, on a 3 legged stand especially.
Oops...wrong choice of words...I meant where the bell housing bolts up which is the rear of the engine. And I have a 4 wheel stand...avoided the 3 wheelers just for that reason. Thanks for the info!!
Old Feb 22, 2009 | 09:27 AM
Bluevista's Avatar
Registered
I figured that, had me scared there for a minute.
I bet that's never been done before.
Old Feb 22, 2009 | 09:58 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
LOL. I had an engine stand that got folded in half by a 455. Took about 45 minutes. We drank beer and watched it die. Then we lopped the tube off of the back and made an engine test running stand out of the base.
Old Feb 22, 2009 | 10:54 AM
citcapp's Avatar
Four wheel stand is the only way to go. Watched a three wheeler toppel over with a hemi on it once wipped out the carb, intake, fuel pump, valve covers, ugly site. I use a 1200 Lb 4 wheel stand with a wide wheel base front and rear.
Old Feb 22, 2009 | 11:26 AM
Not a problem. Just be sure to use Grade 8 bolts, not the Chinesium ones from Lowes Depot. Also, thick (or multiple) washers under the heads of the bolts where they pass through the spider of the engine stand.
If you don't already have a stand, use a four wheel stand with a BBO. I dumped a BBO short block once with a three-wheel stand. Not pretty.
Old Feb 22, 2009 | 12:22 PM
jensenracing77's Avatar
you think a 455 is bad, i did a 394 on an engine stand (the 4 wheel stand). the bell housing is part of the block on it so the engine is about 4 inches farther out on the stand. i think the 394 is alot heaver than the 455 but i am not sure. i was sweating bullets when i put the heads and intake on. looking back now is scars me. don't think i will be doing a 394 that way again. it never fell though
Old Feb 22, 2009 | 12:25 PM
csstrux's Avatar
I think if I was getting that worried, I'd cut a 2X4 or something to block up the front end. Probably isn't a bad idea anyway.
Old May 15, 2009 | 10:59 AM
Vinny72olds's Avatar
Be careful moving or leaning against engine. My 16 year old son sort of fell into the engine and down it went.The right head smacked the concrete floor where the alt. bolts in and pieces went flying. I picked him up told him to get in the truck shut the garage doors and went home. All I wanted to do was wrap my hands around his neck and.....well you get the picture. Now I don't know what to do.
Old May 15, 2009 | 11:04 AM
Oldsguy's Avatar
Past Administrator
You get yourself a new head if you can't repair the damage.......
Old May 15, 2009 | 11:26 AM
I also like the trays under the 4 legged ones that catch the goop.
Old May 15, 2009 | 11:38 AM
citcapp's Avatar
Why didn't I think of that
Get a new head? Yes, also get a new kid Just kidding sort of
Old May 15, 2009 | 11:41 AM
Because neither of us is smart enough to invent the Hula Hoop or the Pet rock.
bocoogto
Aug 26, 2023 06:09 PM
steve e summer
Oct 24, 2011 11:39 AM
Olds92
Oct 25, 2010 09:05 AM
NEWOLDSMAN
Nov 17, 2009 12:19 PM
cts-v
Jan 10, 2009 06:20 PM
