adjusting dwell
adjusting dwell
i was adjusting the dwell on my 68 442 and was using an allen key with no gloves and my arm was resting on a metal part of a trouble light and got zapped somehow. can this happen? or is something wrong under the cap?
Absolutely. Your Allen Key accidentally touched a live high voltage ignition portion of the points, the distributor rotor, possibly the distributor cap or condenser wire (most likely). Since your arm resided on the metal housing of the engine (somewhere) you provided a fast path to ground (-) and were zapped. In most cases you just need to be cautious and use good lighting e.g. flashlight works well.
You got zapped with inductive kickback.. On a running engine the zap feels like AC. An old situation, a reminder to use caution.
People used to get a zap the same way dialing a rotary dial telephone while in contact with either telephone line conductor, or by providing a path to ground perhaps with bare feet.
https://inductive-kickback.com/2019/...asy-to-handle/
Hah. Very cool. Never really involved myself w/ understanding details of inductive properties of electricity. Don't some (at least) electric cattle fences operate similarly - at least the type which use a battery? The zap certainly feels similar - yes, I've received both types.
