AC lever isn’t moving
Old Oct 16, 2021 | 05:23 PM
Rallye469's Avatar
For the life of me I cannot get the AC level past the point in the first picture.
I’ve tried to see if I could:
-manually move the control assembly from the back- Nope.
-Manually move the flap door and linkage - Nope.
-Freeing up and possible binds in the cable - Nope.
Anyone have any ideas what typically binds up on these?
(65 cutlass)
Been reviewing the assembly manual w/o any luck.
Thanks,
-peter
Old Oct 16, 2021 | 06:33 PM
On my 71 that controls the blend door. Every time I pulled the heater box to replace the heater core I had to readjust the cable so the lever would operate correctly.
so is the a new development, or has it been like this for a while?
and has any work been performed on the system recently?
Old Oct 16, 2021 | 09:45 PM
Rallye469's Avatar
I got this car in the spring. After some work I started driving it and it worked but with more effort than I liked.
Now it just wont give.
Where did you adjust it?
Out on the passenger side where the cable leads to?
Theres a lever with a rod that feeds back toward the drivers side to accurate the door.
-peter
Old Oct 17, 2021 | 12:57 AM
The adjustment is on the top of the heater box where the cable attaches to the blend door.
Really dunno if that is your issue or not.
Old Oct 18, 2021 | 02:52 AM
Rallye469's Avatar
It turned out to be the hinge on the door itself.
Just needed some freeing up and lubrication.
-peter
Old Oct 18, 2021 | 06:42 AM
edzolz's Avatar
I had two 65 Cutlass/442's and both had to have that door lubed. Used WD40 and they loosened up.
old greybeard
Feb 22, 2021 11:09 AM
Sandfreaks
Mar 29, 2019 03:17 PM
deaddds
Nov 12, 2017 07:30 PM
sammieolds
Feb 16, 2017 09:25 AM
Grace Stinespring-Welch
Jul 14, 2013 07:29 PM
