70-72 bigblock fender braces
The last set I had used a stud that came out a factory hole the fender in front of the hinges. This set does not. I was told they were removed from a bigblock Olds a-body. Did Olds use both styles?
lol, i just looked up the set i seen on eBay and they were on a dark floor. i went out and took a couple pictures of some on a car i have. it looks like there is a bolt through the nut that is welded to the brace. that bolt is the stud that you see under the hood.
100_8238.jpg?t=1337474007
100_8244.jpg?t=1337474048
Brace???
The last set I sold were slightly different , they did not have the threaded hole with a bolt run thru it like yours or the set I got today , see pictures.
The ´70 SX that I had sold last fall had studs with nuts on the fender side, but I have recently purchased a core support and fender braces out of salvage from another ´70 which had the threaded square nuts attached to the brackets. I am gathering that they were different based on build location, or component availibility, or day of the week. Maybe one of the local Rocket Shaman can give us an answer.
Thanks,
Ted
Just looked at Parts Place. They have this listed new for 59.00. Can't tell from that small a pic, but from the look of the limited number of fasteners they likely have the nuts welded to them?
Part BP1071T
Use 'fender brace' for the keyword
Part BP1071T
I tried to cut and paste the whole pp ad. It does say nut welded on one end fyi
Body Panels - FENDER TO BODY BRACE - REAR INSIDE OF FENDER
THESE ARE THE RODS THAT GO BEHIND THE FENDER AND COWL. CURVED ROUND BAR WITH NUT WELDED ON ONE END. THESE WERE USED ON HIGH HORSEPOWER CUTLASS SUCH AS 442 / W30 / W31 / RALLYE 350.
Product Name Price Quantity BP1071T
(1970 - 1972 Cutlass/442) FENDER TO BODY BRACE - PR
$59.00
$59.00
