68-72 rear upper control arm difference
Old Dec 20, 2019 | 04:26 AM
scrappie's Avatar
I learn stuff everyday. After all these years I didn't realize there was a difference between the 10 and 12 bolt rear upper control arms. ILT offers the two. Can anyone explain the difference? The bushings are all the same correct?
Old Dec 20, 2019 | 06:41 AM
See this >>> https://classicoldsmobile.com/forums...utlass-123231/
Old Dec 20, 2019 | 06:51 AM
Joe & others have addressed this topic (above). This image is simply to provide clarity RE: Part Nos.
Old Dec 20, 2019 | 11:05 AM
fasteddy's Avatar
I just put those (12 bolt ones) in my car this week. I had to grind off a bunch of metal off the control arm top get it to fit on the pumpkin side...
Pat
Old Dec 20, 2019 | 11:28 AM
scrappie's Avatar
12 bolts on cover and type O?
Old Dec 20, 2019 | 12:35 PM
fasteddy's Avatar
Yes. I think it was more because of poor quality control more than anything. You can see how it was not the same on the end
Old Dec 20, 2019 | 02:07 PM
scrappie's Avatar
Yes I can....
Old Dec 23, 2019 | 11:36 AM
monzaz's Avatar
12 bolt CHEVY to all others
12 bolt has a 8.875 ring gear all others are smaller diameter 8.5 making the casting bigger hence the area where it rubs is where the ring gear is. casting buldges and that is why the control arm rubs.
Hope that makes sense.
They used the metal to reinforce so that there was enough rigidity to do the job.
Jim
JD Race
Toms cutlass
Apr 27, 2020 07:40 PM
GlennLever
17
Aug 28, 2015 03:02 PM
Whannah1990
Jan 22, 2015 07:49 AM
RandyS
Nov 19, 2014 11:49 AM
72CUTTY
Aug 22, 2008 08:30 AM
