65 Steering Column
Old January 2nd, 2019, 04:32 PM
sfetty's Avatar
65 Steering Column
OK, stupid question but what is the length of a factory floor shift steering column for a 1965 Cutlass 442. 32 inch? And can you install one size shorter to move the steering wheel back off the drivers and closer to the dash?
sfetty is offline
Old January 4th, 2019, 10:52 AM
There was only one "size." A smaller wheel or moving the seat might help. The column is mounted from the dash underside, and also connected to the rag joint and gear box in the engine compartment.
Koda is offline
Old January 4th, 2019, 03:48 PM
classicmuscle442's Avatar
Have a stock column 65 442 with four speed, plenty of room and I am 6' 4".
classicmuscle442 is offline
Old January 5th, 2019, 05:47 AM
sfetty's Avatar
But what is the length? Considering replacing column with an aftermarket tilt wheel. After re-measuring I think it is a 30" but just not sure.
sfetty is offline
Old January 5th, 2019, 06:05 AM
Should have dimension in manual, mines tucked away for winter.
GTMeach
August 25th, 2018 04:26 PM
1971 cutlasssupreme
July 23rd, 2018 11:17 AM
Fabian Olalde
January 25th, 2016 10:11 AM
HiCompOlds
January 10th, 2013 09:02 AM
68conv455
November 19th, 2011 07:36 AM
Quick Reply: 65 Steering Column
