60 degree spark plug boot
I am looking for a single spark plug wire, red, 8mm customizable length, with a 60* boot. Striking out at Summit & Jegs.....anyone Know of a souRCE FOR one? tHIS IS FOR My 68 350 FOR USE ON THE #7 CYLNIDER BY The STEERING SHAFT. pOiNts iGniTIon....
thANKs
sorry aboUT thE vArYINg CAps....FrICKIN KEYBoarD....
thANKs
Do you mean 135° boots? Like this? There are strictly the boots and terminals for the end of the wire, but if that's all you need....
https://www.jegs.com/i/Taylor/895/46...kaAhWAEALw_wcB
Otherwise you're going to be stuck buying either a universal set of wires, or a spool of spark plug wire and making your own.
https://www.summitracing.com/parts/tay-35271
