1972 CS vacuum line help
Old Nov 11, 2018 | 08:07 AM
yellowone's Avatar
I have a 1972 CS with 350 2bbl carb, auto trans with AC. I am wanting to put engine area back to original and need vacuum line positions. Pictures,or shetches would really help. Thanks alot. Previous owner has plugged alot of stuff on the caurburetor and on the engine components. Have no idea what goes where. THANKS as always
Old Nov 11, 2018 | 11:45 AM
jaunty75's Avatar
Do you have a '72 Chassis Service Manual? If not, you should get one. There is typically no single diagram in the manual with all of the vacuum connections. You'll need to look at each system to see how hoses are routed and connected. For emission control vacuum lines (EGR, PCV, charcoal canister), look in the emissions/tune-up section. For heater/AC controls, look in that section. For cruise control, that section. Power brake booster, that section. Etc.
jaunty75
Jul 3, 2023 11:10 AM
LJ72Cut
Apr 29, 2017 03:39 PM
gesmith02
Aug 21, 2016 12:50 PM
Swede98
Ninety-Eight
20
Apr 3, 2011 02:27 PM
ChefDeadpool
Dec 12, 2010 06:33 PM
