1972 350 Heads
1972 350 Heads
I may need to have my heads rebuilt sometime in the future. I am getting some oil on my plugs and I suspect either the guides or the seals or both. They are stock 350 heads. How do I identify them? Is there any reason to grind the valves differently than stock? My car is a cruiser, 350, thm350 with 273 gears. I am not looking to race it, but if there are a few free or low cost horsepower gains I might be interested. Should I consider other heads and rebuild them? I am just looking for some possible alternatives without breaking the bank or changing the character of the car.
The heads can be identified by the casting number above the #1 spark plug. 1972 should be 7A. These are some of the better SBO heads so no need to go searching for something else.
Olds 350 heads:
1968-69 = 5
1970 = 6
1971 = 7
1972 = 7A
1973-1976 = 8
after that it gets a bit fuzzy for me. I think the 77-up 350s used 3A heads but I'm not positive.
Olds 350 heads:
1968-69 = 5
1970 = 6
1971 = 7
1972 = 7A
1973-1976 = 8
X2. If they are 7a heads then just getting them redone is the way to go. Since your intake will be off you could take the opportunity to have your carb cleaned & carb kit installed. If you have a single exhaust system you could maybe go with a dual system off the exhaust manifolds with stock mufflers. This would allow the engine to breathe better and give you a bit of hp gain without changing the sound much. Also you might find a dual snorkal breather that would help some as well.
Yes, I did see 7A on the heads. I dual exhaust and Quadrajet. I rebuilt the Quadrajet with a kit from Cliff, drilled tapped and sealed all the plugs and it starts perfectly with the stock choke components and is very responsive and smooth at all speeds.
I just didn't want to have these heads done and find out there were significantly better alternatives. Would these get the stock angles on the valves?
